  • SN95 4.6L Mustang Tech
BBK X-Pipe Q
  • Thread starter Thread starter GoneMad96
  • Start date Start date Apr 1, 2004
GoneMad96
262
Cali
Apr 1, 2004
  • Apr 1, 2004
Hey guys i just put on my new bbk x-pipe and sounds bad ass but it is rubbing something bad so i got it back on the lift and found that one side was rubbing against the drive shaft so fixed that problem and it still rubbing on something, any idea what it might be cause i sure can't find it
5.0's 4 ever
The #1 Stunna
5,794
Orlando, FL
Apr 2, 2004
  • Apr 2, 2004
Possibly hitting the transmission crossbrace
StangLou
1,264
Holly Springs, NC
Apr 2, 2004
  • Apr 2, 2004
Are you sure its actually rubbing something? Not trying to be rude lol, but can you feel a vibration or are you hearing something?
Could it be a leak?
One way to check for vibrations since your bbk pipe is all new and shiny is to check for any rub marks on it where it may be vibrating.
Also as crappy as it sounds, you may need to simply take it off and put it back on. Maybe its just how a bolt is tightened or something that is lifing up a certain section causing the vibration or noise.
Best of luck
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
  • Gulftown980x
  • Jul 29, 2026
squeak93
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
G
2001 Mustang GT noise after header and control arm (x2) install
  • gilmo5
  • Jan 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 12, 2025
weendoggy
