bearing knock
  • Thread starter Thread starter speed1972
  • Start date Start date Mar 22, 2004
speed1972
891
Denver, CO - Buckley AFB
Mar 22, 2004
  • Mar 22, 2004
Ok I need some diagnosis help. When the vehicle is cold and cranked up, it makes no noise. After about 15 minutes, once everything warms up, it starts knocking at idle. Wouldn't that be main bearings? or is there something else causing this knock?
thanks, Larry
NKau
1,346
Jefferson, WI
Mar 22, 2004
  • Mar 22, 2004
I'm positive it's either rod or main; can't remember which one specifically does it just after warming up. Once it starts knocking it loses all power too right? Either way, that engine needs to come apart.
speed1972
891
Mar 23, 2004
  • Mar 23, 2004
I'm not sure either but I was hoping I could figure it out so I could know where to look when I take it apart... Anyone else?
hllon4whls
BANNED
2,567
Covington
Mar 23, 2004
  • Mar 23, 2004
In my experience this is a cam bearing or possibly a spun main bearing. I spun a cam bearing. When the car was cold, it would not make a sound, when it warmed up, it couldnt have been louder.
NKau
1,346
Jefferson, WI
Mar 23, 2004
  • Mar 23, 2004
What happens if you try to drive it when it's warm? If it's a main, it will be a total dog; might even stall when put in gear.
hllon4whls
BANNED
2,567
Covington
Mar 23, 2004
  • Mar 23, 2004
Dont think so. If a main is gone, it would still have power until it beats itself to pieces. Unless it starts to sieze. If it starts to sieze, then it wont last more than a few minutes.
Further explanation on my cam bearing issue. The cam bearing was causing an overall loss of oil pressure. Not that the bearing itself was making noise.
What ever it is, if you drove it, the damage is done. The more it runs, the worse it is going to be. Park it and get it fixed asap.
NKau
1,346
Jefferson, WI
Mar 23, 2004
  • Mar 23, 2004
Must have been the rod bearing in my dad's case then; couldn't remember.
speed1972
891
Mar 24, 2004
  • Mar 24, 2004
i will check it out and let you know.. thanks
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
Drivetrain 8.8 trac lok spider gears..
  • rednotch
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 28, 2025
rednotch
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
