i know there are a lot of people out there that say cutting springs is bad and i know i should just get a set of springs from a manufacturer but hear me out. if a set of stock springs is old and sagging and you cut them it would bring it back up to the stock spring rate if not just a little more. cutting 1/2 or 1 coil out of the spring definetly changes the spring rate but wouldnt it be beneficial on a set of stock springs that have 200k miles on them? say youve got 500 in/lbs springs that are so old and worn out that they are down to 400 in/lbs. the springs have 10 coils in them and you cut one out? each coil is equivalent to 40 in/lbs when you cut them, so cutting one coil out would raise the rating to 440 in/lbs. well anyways, im really just wondering if i cut a coil out of my front springs will i have enough adjustment to get a good alignment without caster camber plates? please discuss everything ive said and let me know if ill even need an alignment. im replacing my struts at school and will be using one of the alignment racks to do the alignment afterwards and just want to know if i will be able to do it without c/c plates. thanks
