Beefed Up Torque Boxes?
  • Thread starter Thread starter Codydubb
  • Start date Start date May 9, 2012
Codydubb
149
9
18
Preston, Id
May 9, 2012
  • May 9, 2012
Just curious what you guys have done to strengthen your torque boxes on your foxes? i just installed some reinforcing plates but someone said they are cheap and dont work worth a damn...but i havent seen or heard anything else to strengthen them? pics of anything you have done?
Admin Dude
Jan 4, 1985
43,590
21,751
234
Box behind Walmart
May 9, 2012
  • May 9, 2012
Stainless Battle Boxes
bentley429isBAC
922
188
84
CT
May 9, 2012
  • May 9, 2012
What he said and weld all the points where they attach to the body. Both upper and lowers are tied into my cage also.
Codydubb
149
9
18
Preston, Id
May 9, 2012
  • May 9, 2012
Anyone done a universal 4 link setup? And what kit if you did?
Sharad
ALWAYS choose the V over the P!!! Wait... what?
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
May 9, 2012
  • May 9, 2012
The person you talked to was wrong. Your best bet is to seam weld all of the torque boxes and install upper and lower torque box reinforcements.
And like Bentley, my cage is tied into my torque boxes. Every little bit helps. Those four mounting points are critical to the proper operation of your suspension!
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
May 9, 2012
  • May 9, 2012
As sharad said... Weld the seams put the Plates in... Washers around bolt holes is another trick
Reactions: Sharad
old_blue
1,783
282
124
May 11, 2012
  • May 11, 2012
RICK91GT makes'em and hopefully he will chime in. I don't understand why someone would say battle boxes are waste of time unless the plates you installed are made of tin foil. What kind of "plates" and where were they installed at? Eveything helps especially in that area.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
