been a while... new combo/guess my hp and et thread ... and pics!!!
Green4.6GT
Size Matters
2,910
Regina, Sask, Canada
oh yea.. and a new car too :D
1992 LX hatch, full interior, no bumpers, maybe 200lbs of other weight removed.
just about complete, heres a pic of its current state should be ready to go within a week or 2
internal balance balance eagle forged 347 stroker (10.5:1 @ 65cc)
edelbrock performer rpm heads light porting (2.02 int/1.60 exh, 60cc comb chamber)
compcams solid roller cam (.602/.608)
compcams solid lifters
compcams beehive valvesprings
compcams stud girdle
scorpion 1.6 rockers
dss main girdle and windage tray
canton oilpan 7 QT
victor jr intake (light porting to match heads)
holley hp series 850
msd 6al
msd blaster coil
msd pro billet dist
SPEC clutch
Fidenza Aluminum Lightweight Flywheel
FRPP aluminum driveshaft
T-5z
3.55 gears w C clip eliminators
BBK 1 3/4 ceramic coated longtubes
BBK O/R X
Flowmaster American thunder catback
Aeromotive SS series Fuel pump
Aeromotive 100 micron fuel filter
Aeromotive Adjustable Pressure Regulator
steelbraided lines front to back
ARP fasteners
No Emissions (obviously)
Manual Steering Rack(power bracket was in the car today, when i decided to change the rack, it'll be coming out)
will end up haivng a 100/150 shot on it.. but for the sake of the thread lets go N/A numbers/times
Im gonna go far on this one and say around 375/360tq
looks very stout!!
yea i was shooting for 375-390 hp range.. and similar TQ.. solid roller should help out over your regular run of the mill cam, and the no accessories other than alternator/waterpump should help.
either way as long as its north of 350 to the wheels N/A ill consider it a successful burnt pile of money :D
If the car is set up correctly, and makes around 375-390rwhp and you could get the weight down to about 3000 with you in it, it should run low 11's. My brother's 84gt has a 347 that makes 382rwhp. and his best run so far is 11.01@124mph on motor, its just under 3000lbs with him in it, but the car is more geared toward nitrous.He sprays a 150shot and has run [email protected] with a slipping clutch.
im not sure on the weight, it should be close to 3000 lbs, the car does have airbags that will add a bit, but everything inside the motor is light, no efi etc, and a bunch of weight pulled out of various spots, but it does have a full interior..
im thinking 3150 ish race weight, but ill see when its together, and mine is set up for nitrous as well :D
what trans is he using? and what rpm does he launch at?
