For sale is my 1989 Ford Mustang GT. The car was tuned at Anderson Ford Motorsports it has 2 conservative tunes on pump gas at 15 lbs. of boost. It made 805 HP. at the crank and 683 RWHP. Whether you are looking for a show car, pro-street or just a fun street car, this is the car for you. The pictures only begin to show the beauty of this car. The motor and drive train have less then 2,000 miles on them, and the blower has only been on the car for 250 miles. I haven’t run the car down the track since the blower was installed. On the dyno they did a mock run and it went 9.30 in the ¼ mile, on motor the car went straight as an arrow at 11.4 in the ¼ mile. I would say the car is 99% complete the only thing that isn’t done is a few interior parts in the rear around the roll cage. I will try and list what I have done the car. If you have any questions or want to see more pictures you can E-mail at [email protected] or call Mike at (319)-415-5080. Please serious inquiries only no tire kickers. $23,000 OBO. The car is located in Waterloo, Iowa. Thanks for looking.
Motor-
• DSS Racing Super Pro Bullet 331 (O-ringed and Studded)
• Forged Crank
• H Beam Rods
• Max Quench 18cc Pistons
• Level 20 Block Prep with Main Support System
• Windage Tray
• DSS 7Quart Custom Oil Pan
• DSS High Flow Oil Pump
• Trick Flow Track Heat Cylinder Heads With Port and Polish
• Trick Flow 1.6 Roller Rockers with Cam Push Rods
• Anderson Ford Motorsports Custom B-451 Camshaft
• Anderson Hi-Rev Valve Springs
• 97mm DBX Mass Air
• 75mm BBk Throttle Body
• 225 Chrome Alternator
• March Alternator Bracket
• Prothane Motor and Tranny Mounts
• Romac SFI Approved Balancer
• 1 ¾ Long Tube BBK Headers
• Flexalite Electric Fan
• Fluidine Aluminum Radiator
Ignition
• MSD Pro Billet Distributor
• MSD 6AL Box
• MSD Blaster Coil
• MSD 8mm Plug Wires
• Anderson Ford Motorsports PMS Computer System With Hand Held Controller
• Rear Mounted Battery With Quick Disconnect Outside The Car
Fuel
• Complete Aeromotive A1000 Fuel System includes Tank/Pump/Lines/Rails/Regulator
• Siemens 60 LB. Injectors
Transmission
• D&D T56 With Viper Upgrades
• D&D Aluminum Driveshaft With Loop
• Fidenza Aluminum Flywheel
• Anderson Ford Motorsports Hi-Rev 10.5” Stage III Clutch With 26 Spline Kevlar Disc
• HPM Trans Cross member
• Pro. 5.o Short Throw Shifter
Rear End
• Moser Engineering 9” Rear End
• 410 Motive Gears
• Strange Spool
• Moser Race Axles
• Aluminum Big Bearing Support
• UPR Solid Control Arms
• Lakewood Traction Action Lift Bars
• UPR Battle Boxes and Welded Torque Boxes
• Lakewood Drag Launch Springs With Air Bag
• ARP Long Race Studs
• Rear Disc Brakes
Front End
• QA1 Tubular Sub frame
• QA1 Comp. Lower A Arms With Adjustable Heim Joints
• Lakewood 90/10 Shocks
• QA1 Coil Over Kit
• QA1 Caster Camber Plates
• Flaming River Solid Steering Shaft
• UPR Bump Steer Tie Rods
• Flaming River Quick Ratio Manual Rack
Power Adder
• Polished Vortech V-1 T Trim (Race)
• Renegade 8 Rib Drive Assembly
• Renegade Brackets ( All Have Been Professionally Chromed)
• Mondo Strut Support
• Custom Bent Chrome Piping
• Mr. Freeze Meth. Kit
Other Features
• Weld Pro Star Wheels 15/4, 15/8
• Mickey Thompson Tires
• Stainless Brake Hoses
• 93 Cobra Master Cylinder
• Adjustable Proportioning Valve
• Hurst Line Loc.
• BBK Full Length Sub Frame Connectors
• Maximum Motorsports 6 pt. Roll Cage (With Removable Door Bars)
• Corbeau 6 pt. Cam Lock Harnesses
• Corbeau Wide Legacy Race Seats With Extra Brand New Back And Lower Covers
• All New Carlite Glass
• New OEM Door/Roof Rail/Side Door Moldings
• New Quarter Windows
• New Power Windows
• New Window Motors and Regulators
• New Door Actuators
• Grant Steering Wheel
• Late Model Resto. Door Panels/Carpet/
• Dyna Mat Through Out the Car
• Custom Paint Job
• Frame Rails Have Been Boxed In and all Unnecessary holes Are Welded and Smoothed
• Cervines Stalker Front Bumper
• Cervines Stormin Normin 3” Hood
• Cervines Saleen Wing
• Shaved Antenna And All Badges
• Smoked Front Headlights and Smoked LX Tail Lights
Motor-
• Forged Crank
• H Beam Rods
• Windage Tray
• 97mm DBX Mass Air
Ignition
• MSD 6AL Box
• MSD Blaster Coil
Fuel
Transmission
Rear End
• 410 Motive Gears
• Strange Spool
• Moser Race Axles
• Rear Disc Brakes
Front End
• QA1 Coil Over Kit
Power Adder
Other Features
• Hurst Line Loc.
• New Power Windows
• Custom Paint Job
