postalbunny said:donno if it helps, but the part where the tack is jumpy resembles a problem I had /w the TFI module. After the car warmed up it would sputter (the tach, and the engine rpms) /w part or full throttle around 3-5k rpm... it would drop the rpms back to 3k and climb up.
The 2nd vids look like your rpms are jumping a lot... did the car accelerate a lot? It looks like the transmission slipped or you spun the tires.
Tonight I dis-associated the tach problem with the transmission. The tach even ticks at idle, in neutral as well. I still don't know if its just a tach problem, or a weird misfire.
Now the problem is getting worse. In the upper RPM's, the engine completely breaks up. Its bad. It sounds bad.
So I'm going with some sort of misfire, like everyone has said. I still don't know how the tach is doing as it does, maybe its just a coincidence? Plugs are tomorrow, as well as trying to re-time the car.
I was thinking, I remember a couple of days ago when I had the hood up the dizzy cap wasn't snapped on...not tight at all. I wonder if water could have gotten in there and messed anything up.
