  • SN95 4.6L Mustang Tech
BEGGING for help. intake installed - have problems.
  • Thread starter Thread starter 00filly
  • Start date Start date Jul 20, 2005
00filly
28
Huntington Beach
Jul 20, 2005
  • Jul 20, 2005
ok, so i just replaced the intake manifold on my 96 gt. please, PLEEEEEASE help me. this litte piggy is my ONLY way to work tomorrow, and she's got problems.
when i started her back up, after everything was connected, she wasn't running quite right. she had a bit of a stumble to her when you stepped on the gas. so i thought maybe it was the new manifold and the new cold air kit that i put on while i was at it today. i thought maybe she was just re-learning her air/fuel stuff...... so i decide to take her around the block to autozone to return the torque wrench and she throws a code. then she starts misfiring. THEN she starts throwing a misfire (flashing) code. i get her to autozone and pull the codes, it's p0102 and p0300. i know 0300 is random/multiple cyl. misfire, and it said that 0102 was maf/vaf circuit low intake. i have NO F-ING CLUE what that crap is. everything is reconnected.
i get back home and check her plug wires. one of them popped down a little farther so i think that might have been the cause of the misfire. but she's still got the stumble and the solid code is back (i'm assuming the p0102.)
i'm begging......need help.....BADLY
cobranos
116
Antarctica-The coldest part.....
Jul 20, 2005
  • Jul 20, 2005
Check the wires going into your coils. Make sure they are all pushed into the connector and making contact even though the connector is plugged in. I found this after the engine started running way badly. I ended up using epoxy to keep the wires from coming out of the connector..................
00filly
28
Huntington Beach
Jul 20, 2005
  • Jul 20, 2005
2 of the wires got pulled off the coil pack...we thought we got them back on right, but does it matter which spot they go to?
L
LJ30
New Albany Ohio
Jul 20, 2005
  • Jul 20, 2005
Firing Order, look it up on google and howstuffworks.com before touching an engine again please
00filly
28
Huntington Beach
Jul 20, 2005
  • Jul 20, 2005
well i knew the plug wires made a difference. didn't know the location on the coil pack did. sorry to come off like a dumb chick, i'm just worn out from being at this since 8:30 this morning.
04gtdrop
532
Sac, CA
Jul 20, 2005
  • Jul 20, 2005
little black vert, yes there is a firing order. that should explain why it is running the way it is. i dont know the firing order for your car, but i'm sure you can find it online. make sure that you have all the wires going to the right plug. if that doesnt work post back....
04gtdrop
532
Sac, CA
Jul 20, 2005
  • Jul 20, 2005
here i found this for you, hope it helps. according to this article..... make sure you check your VIN
http://autorepair.about.com/library/firing_orders/bl-fo-5955.htm
http://autorepair.about.com/library/firing_orders/bl-fo-5956.htm
04gtdrop
532
Sac, CA
Jul 20, 2005
  • Jul 20, 2005
ohh here is the main page in case you need it, good luck man....
http://autorepair.about.com/library/firing_orders/bl-ford-firing-96.htm?iam=metaresults&terms=ford
00filly
28
Huntington Beach
Jul 20, 2005
  • Jul 20, 2005
YEEESSSSSS! we reversed #6 & #5!!! SHE RUNS LIKE A CHAMP!!! NO MORE STUMBLE! out of the 5 forums i posted this on, you guys were the only ones that got it! everyone else said "blown headgasket" "vaccum leak" "bad o2 sensor" or some other crap!!! thanks guys!
04gtdrop
532
Sac, CA
Jul 20, 2005
#10
  • Jul 20, 2005
  • #10
yep, the way i look at it.... they help me and i help them. i took me a min to find the info you needed. but looks like it was worth it. It would have been faster but i'm still at work so i cant devote 100% of my attn to the forms and internet ya know? well glad to hear that you got it done....... : )
00filly
28
Huntington Beach
Jul 20, 2005
#11
  • Jul 20, 2005
  • #11
thanks again! you made my week!
04gtdrop
532
Sac, CA
Jul 20, 2005
#12
  • Jul 20, 2005
  • #12
Pearl02
496
Kansas City
Jul 20, 2005
#13
  • Jul 20, 2005
  • #13
Glad you got it figured out man. Pearl02.
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
