Bell Housing
D.Hearne said:
Stay away from pickup truck bells, they use a bigger flywheel than a Stang ( 164 tooth vs 157 tooth)
I thought the later 302's had 164 tooth flexplates? I know the II has a whole different setup, but otherwise, I thought the 76-8? had a 164 tooth, and it was for all applications (again, except the MII)?
You'd have a hard time bolting a clutch and pressure plate up to a flexplate :D I'm not real sure on small block 71-73 Stangs but I'm pretty sure that they used 157 Tooth flywheels. The Stang II automatics had 147 tooth flexplates.
charlies said:
chris,
i don't know the answer to your question. but i would like to know more about your 1976 mach 1. are you sure that is what it is? do you have a picture?
Yea, Im pretty sure it is a Mach 1, I ran the numbers at MustangII.net and it returned that it is a #'s matching Mach 1. The picture I have isn't too great, but here it is. I dont know if you can tell from the pictures, but keep in mind its stripped to go on a rotisserie.
Chris
