  • 1994 - 1995 Specific Tech
Belt Woes.... anyone?
  • Thread starter Thread starter GTA_V6_Mustang
  • Start date Start date Aug 6, 2010
GTA_V6_Mustang
1,326
Miami, FL
Aug 6, 2010
  • Aug 6, 2010
Ok well I had this same problem with the last stang. After deleting the water pump and adding aluminum underdrives after a while the 890K6 belt from advance that fit pretty tight during install stretches after a few weeks and starts to make noise. On the last stang I just put a belt from a lexus sc430 which was 888 gates and never had a problem again. But for some reason on this one the 890 from advance fits fine. but when I try to use the 888 from gates it doesnt fit. Too short by like an inch. I would love to get a quality 890 belt regardless of price but I cant find one anywhere. Any ideas?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Aug 6, 2010
  • Aug 6, 2010
Try a 5060890 from Advance. It's the Dayco version of the gatorback. It's more solid, and doesn't stretch as much.
Kurt
ProKiller
3,064
15
78
PA
Aug 6, 2010
  • Aug 6, 2010
5060885 would probably work for you too. half inch shorter.
GTA_V6_Mustang
1,326
Miami, FL
Aug 6, 2010
  • Aug 6, 2010
Kurt
you really think its that much better then the drive rite because I the drive rite drives me nuts with the stretching and squeaking and the causing the tensioner to smack against the stop at idle.
legalize420
1,541
South Florida
Aug 7, 2010
  • Aug 7, 2010
another option would be to increase the size of the pulley on the tensioner. napa sells a stock size idler pulley without the lip. just swap that out and you should be good to go.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Aug 7, 2010
  • Aug 7, 2010
Not sure it's any better. It's tougher and doesn't stretch as much. I actually used to prefer the drive rite on my car, because with the big cam, the gatorback was too inelastic, and would cause the tensioner to jump too much. But the gatorback definately doesn't stretch as much.
Kurt
GTA_V6_Mustang
1,326
Miami, FL
Aug 7, 2010
  • Aug 7, 2010
so you mean they sell a pulley for the tensioner that is the size of the idler?
legalize420
1,541
South Florida
Aug 7, 2010
  • Aug 7, 2010
they sell an idler pulley that you can use on the tensioner.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Aug 7, 2010
  • Aug 7, 2010
I decreased the size of the pulley on my idle, and went to a shorter belt, and that worked better for me. I just go and look through the pullies at Advance, and pick the one I want.
Kurt
GTA_V6_Mustang
1,326
Miami, FL
Aug 8, 2010
#10
  • Aug 8, 2010
  • #10
im going to give these things a try this week see what works best.
GTA_V6_Mustang
1,326
Miami, FL
Aug 9, 2010
#11
  • Aug 9, 2010
  • #11
Kurt
Ok well I went with that belt seems much better then the drive rite one. And double the price, lol. So far has much more tension then the drive rite ever did so thats good. But if I do have a problem later on ill just do what was suggested and use a bigger pulley on the tensioner.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Aug 9, 2010
#12
  • Aug 9, 2010
  • #12
It's kind of a pain in the butt to change the pulley on the tensioner. If it's any bigger, you can't get the bolt out that holds the tensioner to the accesory bracket. So that means you have to take the pulley off first whenever you take the tensioner off. It's much easier to change the idler pulley (the one up by the ignition coil). I actually went to a smaller idler pulley, and then was able to find a shorter belt that worked better.
Kurt
legalize420
1,541
South Florida
Aug 9, 2010
#13
  • Aug 9, 2010
  • #13
Kurt
its one bolt. takes less than 1 minute to remove. not even close to a pain in the butt. the pulley only cost around $20. much cheaper than a new belt or belt and a pulley.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Aug 9, 2010
#14
  • Aug 9, 2010
  • #14
Yeah, but it's one bolt between the fan, the air box, and motor, where you always skin your knuckles. Changing the pulley at the top yields the same result at the same price without the hassle. You could always put a bigger pulley up there, same price either way.
Kurt
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Progress Thread 1989 LX 5.0 convertible - mild project
  • Scott_S
  • Aug 18, 2025
  • 5 6 7
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2026
DadLife0724
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
