- Aug 11, 2005
- 16
- 0
- 0
I have a 94 gt 5sp and heard a ticking noise from the rearend. I had a u joint replaced on the drive shaft before and suspected it might be the same problem.
When the garage put it on the hoist and in gear you could see a slight wobble on the left side and the caliper would move with the wobble. They removed the tire raised it again and the wobble was still there. The say the rotor is not bent and it must be my axle. Ford wants $440 cdn for a new one and I haven't had any luck finding one from a wrecker.
What I'd like to know is if I am better off buying new or is one from a wrecker good enough and if I wanted to upgrade the gears should it be done at the same time.
I have to drive 1,000 miles to get home so how risky is it to continue driving with the bent axle. The mechanic said the tire will wear out faster and that he wouldn't
worry until it started leaking!!
Any advice much apprecaited. Thanks
Mride is 94gt 5sp w TSW rims and flwmstr american thunder exhst.
Cheers
Cheers
