  • 1994 - 1995 Specific Tech
bent k-member?
  • Thread starter Thread starter kreymis
  • Start date Start date Apr 26, 2010
kreymis
93
peekskill, ny
Apr 26, 2010
  • Apr 26, 2010
well i think its bent. i already replaced front struts and lower control arms. i stil cant get the caster in spec even with caster plates installed. who makes a good k-member for a 94 gt. it has the 03/04 cobra lower control arms already.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 26, 2010
  • Apr 26, 2010
What about the tie rods? Do those control the alignment?
I've never heard of a bent factory k-member. I would be scared to get an aftermarket piece since those arent nearly as strong. Any idea what caused it?
hollywoodstang
1,095
Apr 27, 2010
  • Apr 27, 2010
If you want to get aftermarket K-Member that is strong and take everyday abuse, Get Maximum Motorsports K-Member,
Everyone will have different opinion on this but I personally use AJE RR K-member and am very happy and it is "almost" daily driver car, I haven't had any problems, But it is hard to bend the factory K-member, Was the car in an accident before?
Good luck
kreymis
93
peekskill, ny
Apr 27, 2010
  • Apr 27, 2010
tie rods are fine. they only control toe adjust. it was in a slight accident where i had to hop a curb. no body damage though. a tie rod was replaced due to that. if i buy an aftermarket k member i want to re use the cobra lower control arms
BlackVert
5,589
9
98
Bethesda, MD
Apr 27, 2010
  • Apr 27, 2010
Good luck
i have an AJE as well. i drive it all the time. very happy with it
my son bent my previous k-member a year and a half ago when he lost traction and went over a curb (partially due to driving on summer tires in 20 degree F weather). that was also an AJE. the new one i have now has a different design and looks much stronger than the previous one.
kreymis
93
peekskill, ny
Apr 27, 2010
  • Apr 27, 2010
Can I re use my control arms with that and can u send a link to where u can purchase one
L
Lawbreaker5.0
543
Texas
Apr 27, 2010
  • Apr 27, 2010
Note that if you bent the K member you could have twisted where it mounts and the new K member will not fit without modifications. I have a buddy going through the same process right now. I would suggest taking to a body shop and pay the intial 100-150 bucks for them to check it out. Then it usually only takes a couple more hours to straighten it. The average per hour was 55 bucks around here in Texas. So it ends up being 250 or so for a straight frame/k member.
Just my 2 cents.
GTA_V6_Mustang
1,326
Miami, FL
Apr 27, 2010
  • Apr 27, 2010
Just my 2 cents.
I second that. If it was that bad enough to bend the k-member the mounting spots may have shifted also.
BlackVert
5,589
9
98
Bethesda, MD
Apr 28, 2010
  • Apr 28, 2010
http://www.ajeracing.com/
hollywoodstang
1,095
Apr 28, 2010
#10
  • Apr 28, 2010
  • #10
You can re-use the cobra control arms with AJE k-member, But why? AJE has the control arms you can use with out going coil overs. (MM k-member, you will have to go coil-overs)
as far as frame, just take it to the shop and see if it's still straight, i doubt it's bent that bad, nobody here can tell you if it's bent of not. take it to the professional and get it looked at.
Good luck
95riosnake
630
Pittsburgh, PA
Apr 29, 2010
#11
  • Apr 29, 2010
  • #11
Maybe somehow when you hopped that curb you tweaked the spindle? Just a thought, that's the only other component I can think of that would throw off your adjustment.
O
Back in a Fox
  • Osorio299
  • Jul 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 25, 2026
gkomo
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
