bent radiator support
  • Thread starter Thread starter noslow1986
  • Start date Start date Feb 19, 2009
N
noslow1986
274
oswego Il
Feb 19, 2009
  • Feb 19, 2009
i hit a ditch and bent the radiator support now my radiator sits on on one side. know is the radiator support a bolt on or do i have to take it to a shop and have it bent down. what would be the easy and cheapest way to fix this
bennettracing
280
Ava, MO
Feb 19, 2009
  • Feb 19, 2009
The radiator support is not a bolt in item. Replacement radiator supports are available from several companies, I know Mustangs Unlimited sells them, I believe at a price of $150 or so, but you will need to verify. To replace, you must remove the front clip, front fenders, radiator, headlights, and anything else attached to it. Cut out the damaged radiator support and weld in the replacement panels. I would definately order in the new radiator support before you start cutting so you know where exactly your cut lines need to be for easy re-installation. This will be quite a large job, you may be better off having a shop use a hydraulic jack to push it back to where it will at least hold the radiator in the right place. This job of course will require some form of a paint job on the affected areas to prevent rust as well.
Certainly not the job for an amateur, if you have any doubts, a good body shop should have no problem repairing this. If you have any further questions, please let me know.
-KB
bubba-dough
1,044
Indiana
Feb 19, 2009
  • Feb 19, 2009
+1, or you can go the hill-jack way like its a 1970's rust bucket truck and beat it or come-along it close
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
