best A/F ratio for heads and cams??
east_sidaz
24
I got stage 1 heads and cams on my 99 mustang GT . I know on Forced induction applications the A/F ratio should be around 11.5 max to be on the safe side.
So what is a safe Ratio for my car??
Tuned for maximum power, you'd probably see an air fuel ratio around 12.9 to 13.1 across the band. You can go signficantly richer without a problem, but it will cost a few hp. I'm not sure where the 4.6 is most knock sensitive, but most likely, a well tuned car would have a lightly rich mixture (12.6ish) in the mid range, that leans out to 13:1 by red line.
