If you are talking about using your stock oem O2's to give a display of your WOT a/f ratio then you need to know those results will not be applicable for that application.
The stock oem O2's are only accurate in a very narrow band of operation.
Having said that ... ANY brand of gauge used for that application will be inaccurate.
If you want to know a general or ball park indication of lean or fat, the most accurate display from those kinds of gauges would be driving conditions in Closed Loop, Light Load, or Cruise at close to closed throttle.
Grady
