Best Built up AODE 4R70W Combination?
1. Single Disk Precision Industries Converter (Multi Disk if with Power Adder)
2. Shift Kit (Trans-go, B&M, Lentech VB)
3. Red Eagle Rebuild Kit (Build up innards)
4. Mid Shaft (Replace with Ford Part Number F8AZ-7F351-AA)
5. Replace Roller Clutch with Mechanical Diode (F8Z-7A089-AA)
6. Deeper Tranny Pan (B&M Deeper Tranny Pan adds 3qts.)
7. External Tranny Cooler
I've also heard of using kevlar bands
And yes, most of this info I got has been scavanged from other forums'n such
I ain't no tranny expert so any opinions or different quality brand names would be great and if i'm off track u can slap me. :D
Thats basically my setup...I have a Precision Industries 3500 stall converter, Alto Red Eagle rebuild kit, Performance Automatic full manual valvebody with transbrake, Performance Automatic hardened stub shaft, mechanical diode, a deep pan, and a Perma-Cool trans-cooler...
I only had a chance to put 200 miles on the new trans before the oil pan gasket leaked on me...so I yanked the motor...but I have liked the results of the build so far...
I never made a WOT pass or anything with it, I wanted to put about 500 miles on it before I put it under stress.
DoubleThePower said:
What did you pay for it and where did you find that at?
PI converter - ordered from Precision Industries ~$750
PA valvebody and stub shaft - JD's Performance ~$625
Mechanical diode and deep pan - local finds...cant remember the cost
Alto Red Eagle kit - local...I think it was around $225...but not really sure...
Perma-Cool cooler - Summit...~$100
SPDU4IA said:
I think i'm definetly gona need a bit more bee***e in my tranny. Oh, and FastmanGT hurry up with those 500 miles... I wanna hear how she performs.
The car wont be running for a few weeks...the block will be off to the machine shop for some work and new pistons will be going in...once everything is broken in, I will post up how things are going with it...
I got mine done about six months ago but we put a Fairbanks/Superior shift kit in, harden input shaft and a larger over drive band along with everything else you have listed. The thing is amazing now, the overdrive is now like fourth gear in a stick car. I was a little worried how it would handle a 347 but just mash the gas and away you go.
I was on the interstate this weekend, no one around, got it up to 135 and it was still pulling hard.
SPDU4IA said:
why would they star our bee***e (B E E F A G E)?
Look at the three letters that it edited out.....
Yep I have 4:10 gears. One of the best single upgrades I ever did but you WILL have to get a chip or you will burn your transmission up.
I already had the PI 2500 stall I paid around 1600 bucks that was everything and labor
I got an Autologic chip from JMS but I "think" Superchips or Diablo can do the same thing. If you don't change your settings via the chip the sensors will think you are running faster than you are due to the gear swap. Also, you will hit the rev limiter a lot faster. It won't shift up or down the way it should. It took me two rebuilds to learn an expensive lesson.
If you do have an AODE get the 4:10's. I have been in cars that had the 3:73's and it helped but not near as much as the 4:10's and with that tranny you need all the help you can get. Once the tranny does go and you get one built correctly your car will be amazing. You can also go to Level 10 and read about the AODE trannys there. One more thing after the instal at higher speeds I felt a little vibration but after an aluminum driveshaft that fixed the problem.
Tranny mods, converter, etc combo
Check out our web site:
http://groups.msn.com/Waynes94GT/waynes94gt.msnw
We have a PATC 4R70W that has very similar mods (you can see the list on their website: http://www.transmissioncenter.net/aode.htm) We also have a PI Stallion multidisk lock up converter. All this is behind a CHP306 with Vortech S-Trim, AFM Stg I powerpipe setup running 15psi on pump gas. 450/440 rwhp/rwtq on a mild tune. Best ET: 12.24 @ 112.5 on a 2.0 60' at 5400' altitude (density altitude during the run was 6400'!!). We're currently adjusting the front and rear suspension setup after installing the Baseline Suspension kit from Kevin Slaby. Our pinion angle was incorrect as well as the Instant Center being over 2 inches too low. We have to replace the springs to raise the car. This should put the 60' into the 1.8 range and the car into the 11s at our altitude.
Wayne
Thats some great info Nucking Futs, should save me a few bucks anywho by gettin a chip before I do my gear install. They main reason I chose 3.73's over 4.10's was because I would eventually like to get some power adder down the road be it a supercharger, nitrous, or a turbo of some kind. However, I think i'll be doin a little more work on my tranny first!
And GTWayne, I think your car is now a damn good inspiration for more than a few of us with AODE's. Oh, and great links, very informal.
