Hi everyone,
This winter I am building my 5.0 a little bit. and I want to know what the best cam is for the setup I am going to be running.
I am going to be using:
Trick flow top end kit( track heat)-twisted wedge 170, 1.6:1 rockers
stock bottom end ( balanced and refreshed)
75mm throttle body
30# injectors
255lph fuel pump
90(?)mm MAF
.030" over
not sure if the deck was ever re milled.
The cam I have seen recommended is comp cams XE276HR. it seems pretty good but it would be nice to know if there is something better out there and what type of ptv clearance I would have.
I know the kit comes with the stage1 cam. but.. I feel like I am leaving power on the table with that cam. the car is a daily driver and I don't want to have to cut deeper reliefs in the pistons. any help would be appreciated. and also any guesses at power at the wheels.
Thanks!
75mm throttle body
30# injectors
255lph fuel pump
90(?)mm MAF
.030" over
Thanks!
