Roush Best choice for more power
fallstar01
54
Best choice for more power in Series IV
Alright, I have the following on my Series IV setup on my 02 GT:
Chicane Pulley
Chicane Intercooler
42# injectors
160 degree Thermostat
90mm Lightning MAF
Lincoln Aviator Fuel Pump
Full Bassani Exhuast,
Dense Charger CAI,
75mm Accufab,
NGK TR6 Plugs gapped at .035
the last tune was 408rwhp 411 torque but dangerously lean.
I think there might be some more horses left. I'm looking for reliable, consistent safe power.
What would be the most bang/buck?
Ported heads
Blower Cams
Ported intake manifold, if so, who/where? How much $ am I looking at?
Upgraded Coil packs
Is there a better lnlet kit for the series IV?
Front heat exchanger
Heat extractor hood
intercooler resovoir tank
Saleen bumper (so more air gets into the intercooler)
Dude, that is just nuts!!! What do you mean it depends on how high you rev it?? When you are at Redline, what boost level are you at? I certainly hope that you are not going into the redline rpm's w/ stock bottom end as that will spell disaster for sure...I think the chicane pulley for the series IV is a 12 psi pulley but that can sometimes not be the case if your set up is causing the motor to breath and expel better which causes you to lose back pressure and PSI...
