91mm Turbo Mustang Project Car
cv334
Hello,
I had a few friends recommend this forum to me as a good place to put my car up for sale.
This is one hell of a deal for anyone serious about drag racing...
I am listing my 2000 Mustang project for sale. I have every receipt for all items listed here, as well as labor. Over 50k invested.
The rear end is all that is left to make this thing run 8's (well, excluding meeting necessary SFI requirements with the cage add-ons, parachute, and such). The engine has 5 low-power dyno pulls to 6000rpms, 2 12-second track runs for testing before the turbo was on it, and 500 highway miles. The body and rear have 105,000 GENTLE, mostly highway miles. This car does not see snow, not driven in the rain, and I take excellent care of it aesthetically.
ISSUES
The car is currently drivable. It needs to be re-tuned since the current one is very conservative for break-in purposes. Rear spring perch needs to be replaced- otherwise it squeaks a little (the rest of the entire suspension is brand new). Passenger side valve cover has a pinhole leak at the gasket.
WHY AM I SELLING IT?
I got bit by the racing bug a few years back. Loved every second of it. I built this thing up and before I could even put it on the track I found out I couldn't race anyways for a number of reasons (situational, medical, financial). I am also moving in 3 weeks and have no options to bring it with me. Perhaps it just wasn't meant to be. This is still a work in progress. Don't expect this to run flawlessly and be able to drive cross country- it needs a tune and a small bit of money and time to get it back to perfect streetability. The way it sits now I can drive it to work and around town with no problem- just annoyingly loud and such. The exhaust pops a bit from the tune, but a new tune would take care of it in a heartbeat.
PICTURES
*Wheel is upside down here because I backed into my parking spot. I also have the panels to cover everything in the interior to make it complete.
Here's a list of what I have invested in it:
BASE VEHICLE
2000 Mustang GT - YN Silver, 4R70W Auto, California Model
Currently located in Northeast CT
ENGINE < 2000 GENTLE miles - broken in on dyno
Modular Performance 334ci Shortblock
Diamond MP 11.5cc dish pistons rings, H13 Pins
Oliver Billet Rods
Kellogg Crankshaft
Federal Mogul bearings
Navigator 5.4l block bored 0.020" over
ARP Hardware
MMR Billet oil pump HE Pickup - cryo teflon coated
Max Motorsports extreme duty oil filter relocation kit
Moroso oil water block adapter plate
2x stainless steel water lines
JEGS 2-pass radiator, recessed in support
Auxiliary 2-pass trans cooler
Trick Flow 44ci 2v heads
MMR Felpro Headgaskets
MMR Engine Gasket Set (FMS, OP, etc)
SFI Flexplate
TFS Followers
Modular Performance Custom FI Cams (I have the card)
Comp Cams Adjustable Cam Gears
ARP Headstuds
TFS 5.4 2v Timing Set
MSD Blaster COPs
NGK TR6 Sparkplugs
Meziere Electric Water Pump Relay
ATI Super Damper
FRPP Lightning 2v Lower Intake Manifold
MMR Sheet Metal Intake Manifold Upper for 105mm TB
Wilson 105mm TB
PA Performance Alternator
MR Gasket Open Air Vents
SCT BA3000 MAF
Silver powdercoated valve covers timing cover
Various deleted components for weight reduction (vehicle weight = 3100lbs)
EGR, A/C system, Hydroboost brake system, PS pump, wiper motors and arms, reservoir. I NO LONGER HAVE THESE PARTS
FORCED INDUCTION < 500 GENTLE miles
Turbonetics 91mm .96AR Ceramic BB T6 Turbo
MMR Custom Longtube Hotside Kit - Jethot coated
TiAL 60mm Wastegate
Heatshield Products LavaShield
AEM Boost Controller
PT2000 style W/A Intercooler Heat Exchanger system
Rule intercooler water pump 2 gallon alum reservoir
JGS 60mm Bypass Style BoV
5" to 4" SS exhaust reducer
4" Exhaust exits out the side of the front bumper
DEI heat wrap on hotside Y-piping exhaust pipe, but not headers
Custom 4" inlet piping to intercooler that is hidden under the dash- interior could be made to look 100% stock except for the cage.
Piping is painted silver clearcoated
5" to 4.5" Adapter on inlet side, K&N filter for street use
All boost lines are hardlined and coated
FUEL < 500 miles
Aeromotive Eliminator return system -10 out -8 return
Aeromotive A1000 Regulator 1:1 Boost Reference
GP 100m pre-filter GP 10m post filter
GP -8 fuel cooler
Aeromotive Fuel Rails
10 gallon aluminum fuel cell
RC 75lb HI injectors
Autometer Fuel Pressure Gauge
Aeromotive pump voltage controller
TRANSMISSION < 100 miles
Rebuilt 4R70W
PATC hardened intermediate shaft
New Ford drum
New Blue high energy clutches
Shift-Kit Modified VB
PTC Custom 10" 2800 Torque Converter w/ anti-balloon plate
SUSPENSION < 500 miles
UPR K-Member
UPR Front Coilovers
UPR A-Arms
UPR C C Plates
BMR Solid Motor Mounts
UPR Pro-Extreme Series Double-Adjustable UCA, LCA
UPR Double Anti-Roll Bar w/ quick release for street driving
UPR 7075 Spherical Bushings and housing kit
Flaming River Manual Steering Rack
UPR Manual-MC Firewall Adapter Plate
FRPP 5.0 Master Cylinder
Lakewood 50/50s
REAR < 10,000 miles (needs to be revisited for racing obviously)
Motive 4.10 Gears
FRPP 8.8 Bearing, Seal Kit Support
BODY CHASSIS < 500 miles
DE 8-pt Roll Cage
Wolfe Racecraft TTF Subframe connectors
Roush S3 Body Kit
Kaenen 6" Cowl Hood
MMR Rear Seat Delete Kit
OTHER
Summit Battery Relocation Switch Kit
Summit Racing Seats Custom Brackets
Dark Smoked Headlights
WHEELS TIRES
STREET:
Nitto NT555R 315/35/17 Rears, 275/45/17 fronts
Black FR500 17x10.5" , 17x9"
ASKING PRICE: $18,000 firm - seller is forcefully MOTIVATED
TRADES ACCEPTABLE:
C5 / C6 Corvette (auto only)
'10+ GT (auto only)
Others negotiable that are streetable and auto only
Auto only due to recent wrist/arm injury and long-term pain.
I'd have to ask that trades be worth more than the 18k asking price. I only listed it that low because in this economy it might be tough for someone to scrounge up that amount of cash.
INQUIRIES:
If you have a serious inquiry on this, please let me know what information I can provide you with; video, pictures, etc.
This is pick-up only. You will need a trailer- this isn't meant for long drives at the moment. With a smaller turbo and some other minor changes, it could be much more streetable.
I will check back here religiously, and you can expect a very prompt response from me. I have 3 weeks to sell this before I move.
Thank you for reading!!
