Best clutch cable set up?
The Mustangsteve one is bulletproof, and he will weld the quadrant on for you if you send in your clutch pedal. I've heard nothing but praise for his kit.
The Modern Driveline one also seems to work well, but is a little more complex (more parts to break).
I have had the Ron Morris one for over a year without any problems. I did upgrade to the newer roller part now included in all his kits. The earlier kit had a plastic bushing that didn't work quite as well (longevity issues). Very simple installation that didn't require any hole in the firewall. It would have required a screw hole in the shock tower for a bracket, but I made a bracket myself that attaches to the upper control arm bolt. The clutch pedal effort is less than my old bellcrank setup with my 4 speed, but more than a Honda Civic clutch or even a hydraulic conversion clutch.
Daniel
clutch cable
I have the Mustangsteve kit in my coupe. I thought it was a very good kit and it feels great. It does take a little work to install but I would do it again without hesitation. In addition to welding the quadrant to the clutch pedal you have to locate and drill a hole in the firewall. The lower cowl requires a little "massaging" too.
Lower cowl? Massaging? No hammers I hope.
How did you guys route the cable between the shock tower and headers/manifolds? I've been through three cables and am now looking into having a custom length cable made to turn down in front of the shock tower (between the shock tower and the front of the car).
I had that problem with a mustang steve kit, and ended up returning it because it was causing clearance problems with my rack and pinion. I went with JMC. Both kits are very nice. Mustang Steve's is a whole less expensive and well engineered. Just didn't work with all my steering modifications and headers.
I did end up with the Mustang Steve kit. It was a little harder to install, based on ads for the other kits, but works very well. I am pleased with the decision to go with his and would make the same decisiion if doing another one.
I use the Hi Po exhaust headers so clearance is not a problem. He is very specific about headers that will work.
Modern driveline kit for me...
After crawling around under there, I can't imagine any of these being easy to install. This one was easy to setup, the instructions were good, but placing the components under that dash was a bear. This kit also has the upper end of the clutch lever really close to the dreaded cowl but does have some length adjustment. (I was also juggling a newly added brake booster and master cylinder, so that didn't simplify anything). I've been driving it for 6 months almost daily without a complaint. The cable routes all the way in front of the oil filter on a 289/302, some might object to that. It seems mechanically well thought out and well built. I have no experience with any of the others.
