There is no kit that is warranty friendly, but putting the old one back on and reflashing the computer is east to do.
Would it be better to go with the Ford Cold air intake kit and retune?
87, 89? i have seen 85 in the mountains, but never 83.
IMO, not worth the $$. you are much better off getting another set-up. the steeda intake is similar to the FRPP CAI, but comes with a different tuner. i believe that steeda also makes the FRP CAI, just steeda's own CAI is a little bigger. the tuner will make all the difference you could ask for.83 octane?87, 89? i have seen 85 in the mountains, but never 83.
about the FRPP CAI. it comes with a tuner that only calibrates for that intake, nothing else. you cant adjust anything, not eb\ven for different tires or gears.IMO, not worth the $$. you are much better off getting another set-up. the steeda intake is similar to the FRPP CAI, but comes with a different tuner. i believe that steeda also makes the FRP CAI, just steeda's own CAI is a little bigger. the tuner will make all the difference you could ask for.
I thik C&L is the best mainly because of the heat shield. I bought a Tunable Induction one which looks sweet and makes about the same power on the dyno compared to the C&L, but the heat shield doesn't seal up to the hood and I get a lot of hot air. I made a custom top part to shield it from heat (which makes a huge differance when driving) but I am considering buying a C&L to replace it since I want to open the hood and have it look good for shows...Muscle Mustangs & FF did and article for track times and the coolder air intakes did much better on the track (they tested air intake temp too)
...and painted plastic...I like the C&L kit i got from brenspeed, looks and works good, the aluminum looks nice and looks real sharp with the Ford intake cover i got from gefracing.com. Ford should quit nickle and diming and not make that stuff optional.
remember what the 2V 4.6L looked like?
we have come a long way since then!...and painted plastic...
Looks good and the plastic doesnt hold heat like metal. Its just a dress up for krist sake, the bare intake looks like a Fantom vacuum to me.
Don't forget the WMS CAI, probably the best if you emphasise the COLD part of "CAI" since it seals off that hot engine compartment air better than any of the others (if you buy the box). If I'm not mistaken they won top honors in the magazine tests, but that might have been on the 92-95mm versions.
Also worth mentioning I think, the C&L costs over $100 more than the JLT.
