best engine set up for a procharger D-1
jawsgt
18
ohio
in about a month im parkin the stang and im ganan start tearin it apart. i wanna do a stroker and forged internals so i can run 20 plus psi. wuts the best stroker motor i can go with for a procharger, afr heads and prolly a custom ground cam? also wuts the specs that sum of u guys r using on ur cam for a blown motor?
really depends on how far you want to go and how much power you want to make....i mean if it was me i would go with R302 or older A4 block...maybe old school boss block if i could find one...forged 4340 eagle crank 4340 eagle h-beam rods...around -20cc dished pistons with file fit rings....and i happen to favor trick flow...so i would get the fully ported track heat heads..flow around 320cfm per runner...unless you want to mess with the R-heads and get custom headers...and the box-r would prob make a nice combo...get a nice size tb injectors and other supporting mods...fuel pump..lines...tweecer or stand alone.....and with all that power your going to have to start upgrading rearend drive shaft tranny ect.....your ? is be very broad...:)
oh and as far as cams...stick between 112 and 114 lob seperation and get some good lift like .550 or higher and you should be good to go..
ford racing z303
comp cams 284hr
new comp cams xfi stroker cam...the bigger one....608..the smaller one doesn have enough lobe separation
Well I dont know if this is the best setup but This guy made 608 HP on this setup and it is a 306 setup with AFR 185 heads and Anderson ford Cam and the d1 of course
