fidstang said:There's no magic brand of head that will get you those numbers. Go ahead, buy the little AFR's, but you'll be dissapointed when you still don't make the numbers you want. I've seen plenty of 165's just under 300rwhp.
Why you ask, because it's about cross section, intake selection, rpm range, stroke size, exhaust, gearing, weight of car, trans type, piston speed and induction type.
In other words, it's all about the combo. I bet if you went and got a custom cam made for what you have now. You'll be closer to your goal then just going out and slapping on a set of "better" heads. Just check out this
http://www.camshaftinnovations.com/REDDeath.htm
You must have! If a T-Moss/Thumper combo can get 270HP to the wheels why cant the above mentioned get over 300?Flavadave4 said:You don't think AFR165s with a GT40 and E cam will make over 300hp with right fuel setup? man i must have missed something
AFR's + intake + custom cam gets 350HP "all" the time!!fidstang said:There's no magic brand of head that will get you those numbers. Go ahead, buy the little AFR's, but you'll be dissapointed when you still don't make the numbers you want. I've seen plenty of 165's just under 300rwhp.
Whats the problem? Hell Even Holley advertises 350HP with there H/C/I set up!not necessarily(if we are talking about rwhp). I agree with the "its all in the combo". Those holley kits dont put out 350 to the wheels, and neither do the TFS kits( anywhere from 290+).There are afr 185 347 strokers that dont even reach 350hp if the combo nots right. But there are some that reach way upper 300's. I apologize if your talking about fwhp, i was speaking for rwhp.GTOReturns said:AFR's + intake + custom cam gets 350HP "all" the time!!Whats the problem? Hell Even Holley advertises 350HP with there H/C/I set up!
GTOReturns said:Yeah I know there advertised 350HP isnt RWHP.But take out 18% drive train lose on a fox body and your still above 300RWHP.
An 18% loss is roughly 40 hp.Thats with a 5spd.Of course aod will be more especially if you have a high speed stall.FastDriver said:umm... 82% of 350 = 287 rwhp & 85% (rule of thumb loss with a manual) of 350 = 297.5 rwhp
