Best Rust Remover????
  • Thread starter Thread starter 1FatPony
  • Start date Start date Jun 14, 2006
1FatPony
241
  • Jun 14, 2006
Which is the best rust remover?? I have heard of Por15, Rust-Mort, Eastwood, but which is the best???
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jun 14, 2006
  • Jun 14, 2006
I like sandblasting the best.
I have heard of some types of acids that dissolve rust very fast and leave base metal mostly untouched, but I've also heard downsides and don't remember what acid it was. I don't encounter much rust here.
Jester67
908
TN
Jun 14, 2006
  • Jun 14, 2006
Por 15 and Eastwood Rust Encapsulator do not remove rust they convert it and cover it of the two I like the Eastwood Rust Encapsulator much better. Eastwood also just came out with a new converter that you can use before the Eastwood Rust Encapsulator http://www.eastwoodco.com/shopping/...UCT&iMainCat=373&iSubCat=374&iProductID=15974 and Eastwood Rust Dissolver http://www.eastwoodco.com/jump.jsp?...DUCT&path=1,2,389,417,423&KickerID=198&KICKER but I have no experience with it .
fasttback
471
Northern CA
Jun 14, 2006
  • Jun 14, 2006
It think your talking about muriatic acid (available at your local hardware store).
Jester67
908
TN
Jun 14, 2006
  • Jun 14, 2006
Yah just keep the stuff away from concrete
mikec35
233
NC
Jun 14, 2006
  • Jun 14, 2006
I am sandblasting one panel at a time in the engine bay and using eastwood's rust converter then top coating with rust encapsulator. So many choices you just have to figure out which system you can afford and have the time to do then just go for it..
'69Mach1
45
Northern N.J.
Jun 14, 2006
  • Jun 14, 2006
This stuff seem's pretty good,
http://www.eastwoodco.com/jump.jsp?itemID=1124&itemType=PRODUCT
It all depends on how bad the scale is ,you may want to blast the area, then use the oxisolve ,the good thing about this product is it leaves the surface in a converted "zinc" coating ,if you wan't to get into the acid based product's such as PPG's DX579 ,you need to cut it in with water, it's best to do small areas so the liquid does'nt get the chance to dry on the metal, if you have deep pitting you will have to use a scotchbrite pad and work the area till you get a orange paste ,then wipe the paste off ,re-apply then rinse the area completely ,if the acid get's into an area on the car you can't get to it could be disasterous down the road ,after the complete area you want to treat is finished, you have to repeat the process with DX520 ,another acid that prep's the area ,then coat with epoxy primer ,it seem's like alot of work but after all that it is pretty much bullet proof ,I purchased a gallon of the oxisolve ,I am almost ready for the epoxy on my Mach ,I may be ready this weekend ,I decided to try the oxisolve under the hood ,last weekend I sand blasted that area, it had some scale ,if the oxisolve work's well I'll post the result's ,it sure would be better not to have to deal with the acid based materials.Hope this help's
stangkid88
112
Seattle area
Jun 14, 2006
  • Jun 14, 2006
The only one I have experience is POR15 and I love it. I used it to repaint my trunk after sanding off most of the rust and it's holding up really good. I used the Super Starter Kit and it covered about half the trunk and I plan on buying a quart later in the the year to finish up the trunk and cover the floorpans. Let me know if you have any questions about this stuff and I'll try to help.
Dothang67
133
  • Jun 15, 2006
stangkid88 said:
The only one I have experience is POR15 and I love it. I used the Super Starter Kit.. Let me know if you have any questions about this stuff and I'll try to help.
Where do you buy it? online?
Thanks
Platonic Solid
1,960
CT-USA
Jun 15, 2006
#10
  • Jun 15, 2006
  • #10
www.por15.com
Dothang67
133
#11
  • Jun 15, 2006
  • #11
Platonic Solid said:
www.por15.com
I was just wondering I could buy it from a local HomeDepot or something, since Im going to the States this weekend. So if I ordered it in the por15 webpage it might not arrive in the days I will be staying there.
1FatPony
241
#12
  • Jun 15, 2006
  • #12
Yea is there a place I can buy it from other than online??
Platonic Solid
1,960
CT-USA
Jun 15, 2006
#13
  • Jun 15, 2006
  • #13
Not to my knowledge, but their delivery is very fast. I'm in CT and if I order it before noon on a weekday, it arrives the very next day in the afternoon.
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
9
Paint and Body Rust what to do now
  • 97sn95
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2026
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
D
What's it Worth? 76 Cobra 2
  • dulcimerbob
  • Sep 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 12, 2026
dulcimerbob
D
