best stoker kit
  • Thread starter Thread starter juschilln
  • Start date Start date Mar 18, 2004
J
juschilln
14
bloomfield michigan
Mar 18, 2004
  • Mar 18, 2004
im lookn to do a 347 kit to my fox...but i dont really know tooo much about the topic. i was wondering if u guys give me links for a good stroker kit. i dont think i have enuf patience to piece one together...but if wud be much better that way then let me know. thanks alot
50Dreamer
688
17
38
CT
Mar 18, 2004
  • Mar 18, 2004
D.S.S is the way to go. Im not sure on the website but search for it on here and you should find tons of info on them.
bmo37
2,368
New Jersey
Mar 18, 2004
  • Mar 18, 2004
i disagree chp owns all in my opinion, there 347 stroker doesn't burn oil like a dss will, plus i heard alot of complaints about dss not checking clearances along with balancing and assembly problems, checkem both out. Dss are geared to be striaght race motors not for longgevity or streetability. They have there advantages with there strong main support but you can get one installed on a chp for alittle dough.
www.coasthigh.com
www.dssracing.com
TIMMY2734
1,330
Queens, NY
Mar 18, 2004
  • Mar 18, 2004
if your looking for a stroker kit, contact Brian @ adperformance.com
He carries Scat stuff and is well known around the boards
Jason 302
685
71
68
Newark, Ohio
Mar 18, 2004
  • Mar 18, 2004
331's will not burn oil. CHP's street fighter 347 uses a shorter rod (5.315")to allow the oil rings to sit above the wrist pin, makin it seal better from burning oil. However it gives the engine a lower rod ratio making more force on the thrust side of the piston and cylinder. 331 kits do not have this problem as they have a shorter stoke and keep the oil rings above the wrist pin while maintaining a 5.400 length rod which makes a much better rod ratio, especially with a shorter stroke. 347's have more cubes, but 331's have a better rod ratio. And, as proven by pro engine builders such as Smokey Yunick time after time, a longer rod makes more power. I'm not saying a 331 will make more power, but it would be easier on the cylinder walls and burning oil. And I've heard lots of good things about Scat cranks. Rods-crower, manley, scat=good things. Pistons-Probe, Wiseco, JE=good things.
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Mar 18, 2004
  • Mar 18, 2004
I highly recomend using SCAT Internal Components. There Cranks, and Rods are excellent. There stroker kit's usually come with SRP Forged pistons as well which is a bonus as well. Stay away from CAT and Eagle. I have talked to some well known machinists' who have nothing but bad stuff to say about Eagle Cranks (Something to do with there oil passage design). CAT stuff is made in Taiwan so STAY AWAY.
Anyway go with SCAT, I used there 408 Kit in my stroker and was really imressed with there stuff. These day's you will see the majority of Stroker engine's out there are using SCAT components.
TT91
1,536
Paramus, NJ
Mar 18, 2004
  • Mar 18, 2004
Besides that being the most ignorant statement ever posted on this board...I use DSS internals, but id have to agree that SCAT has the best name out there and is known for their high quality rotating assemblies.
saniutza
147
born in Transylvania, Romania...live in Lusby,MD
Mar 18, 2004
  • Mar 18, 2004
www.coasthigh.com
www.dssracing.com
yep he's right... i wanted to get a 347 stroker and i was looking at the dss stroker kit but after i've made a research i've found out that the 347 burns oil ... so now i'm going with the chp...
408stroker5.0
Mar 10, 2004
639
Mar 18, 2004
  • Mar 18, 2004
Probably burn' oil cause of the piston's they use. If the Oil ring is lower than the pin your going to be burning alot of oil, especially on a street car.
bmo37
2,368
New Jersey
Mar 19, 2004
#10
  • Mar 19, 2004
  • #10
you crack me up nothing i said was wrong bro, next time know what your talking about before you open your mouth, ture or false dss 347 stroker oil rings intersect with the wrist pin on the piston? If you don't believe me call dss up and ask they'll even tell you it does, they'll also say they have oil control rings that "susposedly" stop this problem, but the fact remains it still burns oil.
I wasn't bad mouthing dss but rather telling the truth about what there really made for, there not street engines but rather designed to be all out race assemblies
saniutza
147
Mar 19, 2004
#11
  • Mar 19, 2004
  • #11
I was bad mouthing dss but rather telling the truth about what there really made for, there not street engines but rather designed to be all out race assemblies
you're absolutely right
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
