Best Stroker Kit for 4.6 2v??
GreekStang85
485
Hey guys i am interested in buying a stroker kit for my 03 GT. i want a kit that will give me a good gain in hp but also forged too so i can supercharge it at a high boost and use a bit of nitrous.
68 & 00 GT said:
I'll bet. :)
By the way I've been hearing not to run a 324 if you plan to use a lot of boost b/c the cylinder walls thickness is questionable. Any comments on that ?
The lowdown on the big bore in boosted applications.................
The big bore (whether it be stroked also or not) CAN handle good amounts of boost. I've successfully run 18psi on a big bore stroker with no issues what so ever. That being said, I also know a guy that attempted to run 30psi, and the block split on its first dyno pull (it was making 700rwhp at 5000rpm as it split ;)). Basically, VT does not recommend running more than 18 psi on a big bore AS OF YET because we have not personally tested it about that level. If the car is a street driven car, 16-18 psi is tons of power for a street car. The big bore really helps out the heads for flow potential, thus generating more top end power. If you combined the big bore w/the stroker, you'll have tons of midrange torque, with a chit load of high rpm power. It don't get any better than that! :nice:
