flyingmachine
- Dec 2, 2004
- 32
- 0
- 0
Over's GT said:If you are like most HP junkies you will wear out the rear tires of any given combo first
If you lean towards going around corners fast then the front will go first
the ability to rotate tires now or in the past has great benifits on top of just more (depending on driving habits alot more) miles out of a set, the next biggest benifit of rotating rear to front is every rotation you get whats like a semi-new pair of tires on the front (my cars always drive smother and steer better (less pull) after a rotation, front tires alway wear different then rears perfect allignment or not. *this applies to solid rear axle only
on the other hand, If you have stagered front and rear tires you get the unique costom look, also I know of situations were the rears have been replaced 2 or more times while fronts are fine (these are the burn out guys)
Good post.
). I don't recommend them.
