Best Upper And Lower Intake Manifold For Over 500 Hp
rolandj
17
New Jersey
I currently am running a cobra upper and lower intake and with all my work that is done to the car I believe is too small. I was looking to go with something from trickflow. car has been in garage under cover for so long and I finally have found some time to work more on it and finish it up and go to more shows with my son.
It all has to do with how you are making the power. If it's an N/A engine that spins a lot of rpm, a box intake, or a short runner intake will help. For what you have, I would go with what mikestang said.
Kurt
Trick flow r is a box style intake system II is a short runner intake. Both have different applications.
Oh I agree. I prefer the systeMax but with the blower just don't use the street heat and create a choke point. OP the r raises the power band to the upper rpms with a slight sacrifice in the lower range.
I run the Systemax 2, so I'm biased. However, it probably is the better intake. It's actually has pretty long runners. It's also very pricey though.
Kurt
