best value solid motor mounts?
do you know how to weld? Do what I did, mine cost me $0. I took the stock motor mounts and welded a piece of 1/4 inch steel between the base and the part that bolts to the block. All I did was cut two square pieces of the steel, and welded one to each side. Works like a charm. My solid mounts cost me nothing. Good luck Ted
