Best way to wake up my lazy auto tranny
I have recently acquired my bog standard '04 GT. I love the car and the motor but I am less than impressed with the standard auto transmission. Don't get me wrong if I kick it down HARD the car is quick, but generally I find the throttle response pedestrian, and the transmission quite lazy with vague, tedious shifts.
I WAS expecting this from the standard auto to be honest from what I had read but the right car came up at the right price and I decided to go with it rather than look for a manual. What mods do you recommend to 'wake up' the auto ? I will eventually be looking at other power/chassis mods for the car as well but these will be relatively mild - I doubt I'll put much more than 400 hp through the transmission in the foreseeable future.
I'm in the UK BTW but I can source parts in the states without too much trouble and have access to some local technical expertise if the mods are beyond a basic DIY job. THX.
I would definitely get a transmission cooler if you are gonna bump up the line pressure. Heat is the number 1 killer of transmissions.
I saw a thread on another forum just yesterday where a Ford tech posted commenting on a guy that brought his '04 GT in with only 10K on the odometer and a transmission that was already slipping. The guy was dumb enough to leave his Predator hand held sitting on the passenger seat. He had maxed the settings for line pressure and shift firmness. Needless to say, he will be paying for the tranny himself.
Was he saying the Predator is the reason for the slipping? The Predator doesn't really have a 'line pressure' setting. You can increase the shift firmness up to a certain point. It won't let you set it sky high. Now, that only means the shift occurs quicker and there's less slipping -- which means less heat generated. I'm not sure how the Predator can cause this guy's transmission to cook. He must have been brake stalling a lot or ran high RPMs for extended periods.
You are correct, the Predator was not the cause of the failure. Usually though, increasing shift firmness is done by increasing line pressure. People don't usually do that for their daily commute :D Also mentioned in the thread on the other site is that the guy went through the stock tires in those same 10K miles so yes, he was abusing it.
streetstang03 said:
never heard anything bad from anyone about the PI Stallion TCs
are the CircleDs cheaper than PI Stallion?
I have heard and seen bad things about PI torque converters!
CircleD is comparable or slightly cheaper than PI but they build a much better TC.
