better way to jack up the car?
aar0s
1,015
55
69
Is there a better way to get the back end in the air with the weight off the tires than jack stands under the sub frames? :shrug:
this method makes me nervous!
If you're just trying to get the rear-end in the air, jacking from the rear housing always worked well for me. It leaves the suspension loaded, though.
Chris
I don't jack the car by the subframe unless SFC's are welded. I've seen mustangs bend when jacking like this.
Instead, i jack by the pumpkin and put the stands under the subframe or on te axle tubes together.
Up front, i lift in the center of the k-member and put the stands on the outside edges of the k-member or under the ball joints on the a arms if i want it loaded.
