Scrapla347 Active Member Apr 23, 2020 205 68 38 Florida Sep 28, 2024 #1 Sep 28, 2024 #1 I want to jack up the driver side of my 90 GT. I'm curious on the safest way to do so. Should I jack up using the K member and pumpkin then place jack stands under the front and rear frame rails?
M Monkeybutt2000 Mustang Master Aug 11, 2019 1,387 851 133 Lafayette,IN Sep 28, 2024 #2 Sep 28, 2024 #2 Pretty sure I answered this on FB. Jack it up just how you described. The frame rails are fine. Do you not have subframe connectors? Reactions: Scrapla347
Scrapla347 Active Member Apr 23, 2020 205 68 38 Florida Sep 28, 2024 #3 Sep 28, 2024 #3 Thank you and Yes I have subframe connectors .
Scrapla347 Active Member Apr 23, 2020 205 68 38 Florida Sep 29, 2024 #4 Sep 29, 2024 #4 Monkeybutt2000 said: Pretty sure I answered this on FB. Jack it up just how you described. The frame rails are fine. Do you not have subframe connectors? Click to expand... Can I use the subframe connectors to jack the car up? Mine are welded on each side and then bolted in the middle to the seat bolts. Reactions: flynndawg
AeroCoupe lube between the nut and the face. I know my lubes Founding Member Oct 28, 2001 6,191 4,292 183 Claremore, OK Sep 29, 2024 #5 Sep 29, 2024 #5 I do it all the time but not in the middle of the car. Reactions: flynndawg, Monkeybutt2000 and Scrapla347
Scrapla347 Active Member Apr 23, 2020 205 68 38 Florida Sep 29, 2024 #6 Sep 29, 2024 #6 AeroCoupe said: I do it all the time but not in the middle of the car. Click to expand... Ok thank you!
CassieL Active Member May 15, 2024 128 130 53 Tyler Texas Oct 26, 2024 #7 Oct 26, 2024 #7 Put the stands under the axle and control arms, that was the car is sitting the way it would on the ground. Reactions: Scrapla347, AeroCoupe and General karthief
