Not sure why you would think that. The Cobra uses 17" wheels, just like a Mustang does. The brakes should fit just fine with the stock spare.xseler8 said:Your Gt spare won't fit. You'll need a Cobra spare.Good luck with your new set up. They will look good & stop great.
I see....I was not aware of that. Boo for Ford for going el-cheapo with the spare tire size then.bdcardinal said:cobras have a 17" spare designed to clear the 13" brakes. the GTs i believe use a 15 or 16" spare.
Gearbanger 101 said:Not sure why you would think that. The Cobra uses 17" wheels, just like a Mustang does. The brakes should fit just fine with the stock spare.
I thought of that to, but what do the guys that went with the 10.5 wheels and 315 tires on the back of their car do when the blower a front tire in that case?Stang|ess said:If you have a front on the flat, then put a rear tire on front, and spare on the back.
Baer/Alcon and Wilwood make a set but they are $3000+. Too much for the Chassis without full race modification IMObdcardinal said:i dont think anyone currently makes 6 pot fronts for our mustangs, otherwise i wouldve goten them.
the most pistons ive seen on one caliper were 12 on a Mercedes i did a flat repair on.
You'd want 6-piston calipers too if you had to haul your car down from 198mph like the new Zo6 does.gtstangau said:The new z06 has some big humongus 6 piston calipers on it. I want some stopping power like that! Is there anyway to get a 6 piston caliper for a mustang?
