  • 2.3L (N/A & Turbo) Tech
Big engine swap problem
  • Thread starter Thread starter custom1106
  • Start date Start date Oct 29, 2006
C
custom1106
  • Oct 29, 2006
Finally got a chance to work on my '86 Ranger 4x4 2.3 5 speed this weekend. Last weekend I had picked up a junkyard 2.3 motor out of an '87 mustang. Everything swapped over great, did it pretty quickly.
But..
I went to install the new pilot bearing in the mustang motor, It wouldn't fit. Mind you the motor was out of an automatic mustang.
This is the only thing holding up the project, very frustrating.
I have tried both Ranger and Mustang pilots niether will fit (too big for the bore on the crank). What should/can I do now? I need to get this truck going by wednesday, I'm "borrowing" the shop space.
Thanks for the info....
Custom
P
Ponycar
90
Virginia Beach VA
Oct 31, 2006
  • Oct 31, 2006
Put the bearing in the freezer overnight or so. this will shrink the bearing diameter enough to fit.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Oct 31, 2006
  • Oct 31, 2006
Is it just slightly too large, or is it way too large? If it looks like it should fit in, but doesn't, try Ponycar's idea first. I think I used a piece of 1/2" Nylon plate and a hammer to install the PB in my roller 302. That or it was aluminum plate, I forget. I used the plate as a pad so as to not wreck the bearing.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Foxtoberfest 2022
  • FastDriver
  • Sep 6, 2022
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2022
Ford Moore
F
