Big enough radiator
  • Thread starter Thread starter bi19tri
  • Start date Start date Sep 16, 2006
bi19tri
45
  • Sep 16, 2006
Should the hd tree row rad be big enough for my motor?
marine_2003
427
Lake County, FL
Sep 16, 2006
  • Sep 16, 2006
Honestly, the radiator isnt the only thing, you will need a good fan, a high-flow water pump, and the good radiator and cap. It should be big enough, it also depends on where you live and how hot it gets.
bi19tri
45
  • Sep 16, 2006
I just want to know if I should waste energy there or pop for an alum to start with. You still in the Corps?
M
mfewtrail
82
North GA
Sep 16, 2006
  • Sep 16, 2006
My father's car has a combo like yours and he runs the HD three row radiator along with an edelbrock water pump, and an electric fan(not sure what brand/model though). We run a 160* t-stat in the car and the highest temperature I've ever seen it hit was around 180-190* when it was 95-100 degrees outside and we had the ac blasting. The temperatures I stated are from an aftermarket mechanical temperature gauge, the stock gauge in the cluster on his car was horriby inaccurate.
Nopantz
234
NJ/US Merchant Marine Academy
Sep 16, 2006
  • Sep 16, 2006
juss to let you know i have fluidyne aluminum radiator and could not be any happier....such a great product...next for me is a electric fan and water pump....because like said before you need it all to keep it cool
vristang
4,933
101
124
Seattle
Sep 16, 2006
  • Sep 16, 2006
I'm using a 2 core HD rad in the 408 right now. With a 197F stat my temps have been dead consistent at about 205F.
My compression is less than 9:1 though. We'll see what happens when I rebuild to over 11:1. LOL
I say stick with what you have, until you have an issue.
This way you aren't spending money on things you don't really need.
My thoughts,
jason
marine_2003
427
Lake County, FL
Sep 16, 2006
  • Sep 16, 2006
Nope, got out february of last year. As for the Aluminum Radiator, you can ask anyone on any forum site that has an aluminum radiator, and they love it.
bi19tri
45
  • Sep 18, 2006
Any one else with any thoughts?
Fox Vacuum tree replacement?
  • 387lx
  • Mar 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2026
gkomo
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
H
Brand New Built 302 overheating
  • hassler
  • Sep 26, 2025
2K
Rcdgl
R
