Biggest DR withOUT rubbing
  • Thread starter Thread starter willys1
  • Start date Start date Jan 3, 2004
willys1
1,004
New Jersey
Jan 3, 2004
  • Jan 3, 2004
I have a 93 LX with 16 inch pony wheels,whats the biggest size I can go with, without any rubbing? I'll be going with BFG,how many miles do these last?
Black 93 Fox
1,995
Vancouver,Washington
Jan 3, 2004
  • Jan 3, 2004
I would like to know also. I got the same wheels on my 93 lx.
5.0 HOtrain
2,247
New Hampshire
Jan 3, 2004
  • Jan 3, 2004
I run a 275/50/15 on a 15x8 weld with 5.5 bs. I had to lightly massage the inner fenders BUT....they fit. You could run a 255/50/16 maybe on the ponies or get a set of 15's for the track and throw them on some 10 holes like a 235/60. Good luck.
mike.
what_stanger?
I am the mailman!!
1,697
Northern Illinois
Jan 3, 2004
  • Jan 3, 2004
i use a 255/50/16 BFG drag radial, and don't rub, i have removed the quads, and have the car lowered....
i've cut a best of a 1.70 60' on nitrous, and then 1.78 NA, they're workin' for me.....
willys1
1,004
New Jersey
Jan 3, 2004
  • Jan 3, 2004
Do they fit with the quad shocks on?
5.0 HOtrain
2,247
New Hampshire
Jan 3, 2004
  • Jan 3, 2004
Forgot to mention I have also removed quads
NKau
1,346
Jefferson, WI
Jan 3, 2004
  • Jan 3, 2004
I have the 255/50/16 BFG DR's, and they generally do not rub unless I hit a bump while cornering pretty hard. These tires are pretty well unmatched in terms of overall dry traction, but do wear out in a relatively short amount of time. I'd suggest Nittos for a car you put a lot of miles on.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jan 3, 2004
  • Jan 3, 2004
just curious, i checked a site once but they dont make a 265/60/15 DR do they? BFG that is...?
willys1
1,004
New Jersey
Jan 3, 2004
  • Jan 3, 2004
Yea ya know,Ive heard people say that about the nittos,but they also say they dont have the bite that BFG have.What do ta think,10,000 miles withBFG?Did you take your quad shocks off?
what_stanger?
I am the mailman!!
1,697
Northern Illinois
Jan 3, 2004
#10
  • Jan 3, 2004
  • #10
i don't know...
they do rub if i corner hard thoguh, now that Nkau said somthjing, they do if i corner hard, but my car is lowered, and it sags on the passenger side from all of my SIIIIIIIIICk launches
NKau
1,346
Jefferson, WI
Jan 3, 2004
#11
  • Jan 3, 2004
  • #11
My cars quad shocks were removed before I bought it. I haven't run Nittos before, but unless your car will only see track duty, there's no reason to not consider running them. I don't think they give up THAT much to the BFG's. The general consensus seems to be that the nittos last about 15,000 miles and the BFG's............not half of that. Like I said before, if you don't put many miles on your car go with the BFG's. One thing about DR's that you should keep in mind is that although they are DOT approved for street use, I don't like to be on the freeway when rain starts falling if you catch my drift.
willys1
1,004
New Jersey
Jan 3, 2004
#12
  • Jan 3, 2004
  • #12
Justed looked up nitto drag radials,they make a 245/50/16 does anyone use these,and will they fit without taking off the quad shock?
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Wheel backspacing
  • Brad Hanks
  • Sep 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2025
Brad Hanks
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
