Billet steering columns
  • Thread starter Thread starter no_3
  • Start date Start date Jul 31, 2005
N
no_3
73
  • Jul 31, 2005
Anyone have a billet steering column?
What do you think and where did you get it?
4MuscleMachines
417
South Texas
Jul 31, 2005
  • Jul 31, 2005
I am also planning on ordering a polished tilt column, narrowed it down to Flaming River.
yeloxr7
429
  • Aug 1, 2005
Most of these aftermarket columns are wired with a GM hook-up for the horn and turn signals. A horn relay needs to be added to the system and the wiring adapted into the Ford car wiring harness. Flaming River's column (and I bet Ididit's and any others are the same way), when it is set up for a Ford factory steering wheel has kind of a mickey-mouse adapter for the horn. GM does not use a slip ring setup like ford, there is a plastic piece with a wire that goes through the base of the steering wheel. Holes need to be drilled in the base of the wheel and there are a couple of plastic adapter pieces that don't look too attractive. If you're using one of these columns in conjunction with an aftermarket steering wheel, get the "standard" (GM) column and use a GM adapter kit for the steering wheel.
N
no_3
73
  • Aug 1, 2005
So if I want to use a delux mustang wheel do I use all the bits off my old column?
Also does anyone know of a column that is not polished but just in a machined alloy look?
yeloxr7
429
  • Aug 2, 2005
You have to use the horn adapter stuff that comes with the column. Make sure if you get one that it will work with a FORD steering wheel. Most of the aftermarket ones are set up for GM. the spline where the wheel mounts is different and the horn setup is a LOT different.
steemin
201
Ft. Wayne Indiana
Aug 2, 2005
  • Aug 2, 2005
My car has a Flaming River brushed aluminum column with tilt,hazard switch and cruise control built in.. I am using a Momo steering wheel.
I went with brushed alum. because my dash abnd glove box door are also brushed alum. Trying to be consistent with the "theme".
The cruise control stalk looks a little out of place with the black plasic controls.
Forgive me but I really wanted cruise.
Scott
L
69 tilt steering column endplay
  • loubischoff
  • Feb 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 10, 2026
loubischoff
L
T
Aftermarket Steering Column
  • Tas_Jak
  • Jul 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 18, 2025
Tas_Jak
T
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Can anyone identify this electrical plug?
  • 93.5.0GT
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2025
Mustang5L5
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
