Biting Off More Than I Can Chew
CarMichael Angelo
8,909
234
Birmingham, al
like I don't have enough custom junk on my plate,...I purchased the stuff to rebuild my 4R70W today.
Total tally for everything ended up being just shy of 1200.00.
What that gets you is:
1 10" custom tailored converter.
( flash to 2500, footbrake to 2100)
1 hardened input shaft.
2 upgraded accumulator thing-a-ma jigs.
1 full manual valve body reprogramming kit.
1 Rebuild kit W/ alto red clutches and Kevlar bands.
1 "Rebuilding a 4R70W transmission for dummies" handbook.
I've rebuilt several c4's back in the day, so I'm ok with the process. And I have relationships w/ a few trans guys that can help me with the clutch drums, so I think I'll be ok.
Now, just to find the time........
Don't think because you have done a C4 that doing a 4R70W is going to be the same. I did a T/H400 and it was easy. Years later I did a 700R4, and there was no similarity. Total pita, and I won't do it again.
Kurt
Kurt
A 4R70W is nothing more than a glorified AOD with lock-up and the AOD is nothing more than a glorified C-6. So it is kind of the same thing only different.
I hope Ford does it different from Chevy, because I initially thought the 700R4 was a T/H 350 with an extra gear. My assumption was wrong. I honestly don't know with the Ford transmissions, because I have taken neither one apart. I just don't want anyone to go into a 4 speed with the hopes that it will be just like the 3 speed they took apart earlier.
Kurt
As long as you have transmission guys who can help you with the clutch drums you will be a lot better off. The T/H 400 was all stack and play with snap rings. The 700R4 had a bunch of clutch packs that required special tools to compress to release. That and the stupid monster snap ring in the case lugs is what got me.
Kurt
The only thing I can confirm first hand is that the case of the 4r70W is MUCH larger than the case of a C6, so there has to be something different going on inside to justify the size difference. So good luck Mike, do us proud like you always do! Worse case scenario, I know a guy here in CR that will screw you over if you need a rebuild.
Reactions: tannerc91gt
I stand corrected, I had been told by someone somewhere that the AOD was an O/D added to the C-6, and since every FMX I had seen was a cast iron cased s.o.b. I did not think that they were related.
common mistake. the other part of the mistake is that the FMX has a removable bell housing like the C4, and the AOD doesnt.
I had a 4R70W that was highly modified and had the bell-housing cut off so a SFI bell-housing could be bolted on. That whole project is a thread unto itself and may be told here someday.
Ahem.
A 4R70W is an improvement on an AODE. Superior to the AOD/E in it's ability to handle torque. They are basically the same, as several of the internals interchange. From what I understand, It is Only related to the FMX in gearset design, but other than that, share nothing else w/ that heavy cast iron POJ.
I approach nothing lackadaisically, (whew)....I expect the 4R70W to be more difficult from the start. The fact that I am circumventing the computer control via the Transgo valve body modification kit, that will give me 100% manual control of the shifts, w/ lock up of the converter, and O/D controlled by a button, should make the thing a little less of a pain in the ass.
We'll see. The stuff'll be here next week, and I'll start that process when it arrives.
that is kind of a common mod with ford overdrive automatics. lentech for instance does this so they can puth ford o/d transmissions behind a variety of engines that originally didnt have an o/d trans. for instance, you can put an AOD behind a 390 in a thunderbird from the 60s if you like.
Here it is two weeks later, and my DIY rebuild of my 4R70W is complete. Not that it took two full weeks to do it (actually, the entire process was more like 8 hours, and even that is probably 2-3 times longer than it would take somebody who knew what they were doing to do it.)
I'm here to tell you that while it isn't that hard to rebuild one, the proper tools, or lack thereof is what makes it impossible for average joe to do.
I converted this trans to full manual, w/ an electronically activated OD, and Lock up of the converter. That requires the installation of a transgo kit. The valve body part is typical if you've ever installed a shift kit before, but to give the transmission it's full manual capability involves replacing the electronically controlled EPC solenoid w/ an old school vacuum modulator. That also required drilling the case for the vacuum barb that acts as a pass through for the vacuum line to that modulator.
There is one small problem w/ using a vacuum modulator to control the line pressure that will allow me to manually shift the thing though, and that is the turbocharger. Vacuum will cease almost immediately in this combination, and the diaphragm in a vacuum modulator will cease to exist equally quick once boost is applied. There are two solutions to the problem, one of which I am unsure of.
1. Use a Transgo sourced vacuum bypass kit. (a glorified check ball in a tee w/ a spring out of a Bic Click to shut off boost pressure to the modulator, and vent it to atmosphere.
(in my mind, this creates a boost signal leak)
2. Tee the vacuum reference from the intake of the turbo.
( This is the one I'm unsure of,..is the vacuum signal in front of the impeller the same as intake manifold vacuum?)
Anyway, I digress.
The only real tool to take the transmission apart is a homemade bridge to span the servo covers w/ a bolt threaded through it to compress the servo pistons enough to get the snap ring out. That and a slide hammer to pull the front pump. I made the tool, and had a cheapo slide hammer and in about 30 minutes the whole thing was apart and on my bench.
The valvebody mods were next,..... again typical if you've ever did a shift kit before.
Getting the clutches replaced in the three clutch drums was a little more difficult. Fortunately I have a guy at Mr. Transmission, and leaving the three drums w/ him for a couple of hours netted me three drums w/ new Alto red clutches installed when I came to pick them up.
Net cost= 0$
Old sealing rings used what was/is called a scarf cut seal. Simply stated, its just a diagonal slice to allow you to spread the ring enough to get it over the shaft, and into the groove. New sealing rings are solid, and made of teflon. They require yet another tool to install them, and then compress them after installation. (which I don't have as well) That required another trip to yet another trans shop down the road where the guy stops what he's doing, and installs my 4 sealing rings for me while I stood there.
The "special tool" he had was knowledge in the end, he simply used a pick to stretch the rings over and into their respective grooves. Once they're stretched they need a tool to compress them to their final shape. On one set of rings, he used that tool. On the other he used two standard fuel line clamps, and sent me home with them clamping the rings. "Take the clamps off when you get home, and you'll be good".
Net cost=0$
Once back home w/ everything in hand, I start the process of assembling the trans. This should've take about an hour.
Remember however, we're talking about me."Do it twice Mike" is what my friends call me.
Apparently for good reason.
The trans assembles like a tower. Stood up on end each sub assembly stacks on top of each other until you reach the top of the tower where you cap it off with the pump.
Round one had me at the top when I remember that I wanted to ck clutch pack clearances.
I pull the stuff back out. I measure clearances.I build the tower again.
Reading the assembly guide, I become aware that in order to properly guide the servo pins onto their respective bands, you should install each servo at the stage of each band install.
One of those bands is now three assemblies buried in the tower.
I pull it back apart. Install the OD servo, and start to build the tower again.
Completely assembled, this trans is a heavy pig. Each sub assembly is heavy in it's own right. Some of those assemblies are merged together with other assemblies w/ nothing but gravity holding them together until the whole thing is bolted back together. I was lowering one of the assemblies into the case when, as I moved it from the bench to the trans, one of those "merged assemblies" came unmerged, and hit the floor.
What followed next was another slow motion moment for me, as I watched 15 lbs of planetary gear set w/ a one way sprag attached fall to the floor and promptly explode across the garage floor. 13 roller bearings scatter to the four corners of the room.
NOOOOOOO!!!!FFFFFUUUUUUUCCCCCCKKKKKK!!!
I spent the next hour crawling around the floor looking for those stinking bearings.
Once I find them all, I reassemble the sprag, attach it to the gearset, and reinstall the assembly into the trans. The rest of the build moves along w/o incident.
All through the whole build, there is reference to a little tubular screen that was supposed to be in the case. Mine didn't have it. There was a hole where the screen was supposed to go, but I had no screen. I simply figured that my version must not have had one. I put it together w/ out one.
I'm putting on the pan, and I notice this little bag laying on the floor. Inside that little bag is this little tubular screen.
Go figure.
I take the pan off, remove the filter, unbolt the 20 some odd bolts that hold the valve body in place, remove that, and stick that little stupid screen where its' supposed to go.
Put the valve body back in place, bolt the pan on, and just as I'm tightening the last bolt, finally done w/ this b itch once and for all, I notice the filter is still laying on the bench.:doh:
