Black build-up in the tailpipe
rude_life
372
Does it mean anything if there is somewhat thin layer of black stuff on the inside of the tailpipe. The left side has more than the right by the way. Any ideas?
Thanks...
Kris
rude_life said:
Thats what i thought. That in might indicate a lean condition?
No, not lean. Lean would mean there is more air than required to burn the fuel. Likely your situation is opposite, meaning there is more fuel than required for the amount of air present. This leads to gas molecules unburned and in the exhaust, which could (and, likely, would) deposit on the pipes.
running rich ro youre just seeing all the oil that is being burned after getting sucked into your upper intake through your pcv.just got done swaping heads and intake and when i pulled the intake i couldnt believe what i saw.the heads looked even worse,so did the pistons.what a freakin mess.no wonder my car ran like a big pos.hopefully the oil seperator will relieve this problem.
