Black smoke under acceleration
  • Thread starter Thread starter cjman15
  • Start date Start date Aug 17, 2004
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Aug 17, 2004
  • Aug 17, 2004
When my car is all warmed up, I take it down tha road and if the throttle is about 75%+ open it will start to smoke pretty bad... especially once it gets over 3000 RPM... what could be causing that? It doesn't seem to smoke any other time... just when i'm gettin' on it
dastang2
2,020
tx
Aug 17, 2004
  • Aug 17, 2004
do you have any codes and did you convert to a carb. you are running rich for some reason. if you have a carb then maybe you need to adjust something. if it is still efi, while the engine is off, take the vacuum hose off of the fuel regulator and smell the hose ends. if it smells like gas then replace the regulator. i don't know what else to tell ya. check for vacuum leaks too.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Aug 17, 2004
  • Aug 17, 2004
i think i need a regulator anyway
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
