"BlackOut" is out for the count *pics*
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
so. on my way to Jegs today. going down the highway start smelling the burning smell. glance at my oil pressure gauge and it starts to fall from a cruising 30psi to 25 then 20 then 15 then 10 and flicker to 15 and back down then nada shut off and coast into parking lot down exit ramp.
oil trailing behind me. smoking from oil all over the exhaust. and no oil showing on the dip stick.
so trailer it home.
front of motor is clean. some drips all over. oil pan is clean. where it blew all this oil out of it beyond me! oil change new filter and holding 50 psi at cold idle and not dripping a drop! it didn't blow out the oil filter. nothing. the under side of car is covered. checked for a clogged pcv and it fine. checked plugs. fear the worse of massive blow by. just running really lean.
the exhaust is clogged. thinking this may have been a cause but im still looking into it. picking up a new catless X-pipe from Jegs in a few days. its in the garage for now. this is when have a second car or truck comes in handy!
looks good on the trailer though! haha
not the oil gauge fitting or anything like that. filter was clean. no oil leaking. oil pan is clean no oil on it. i have no idea where it blew all this oil out off. but it only drainned enough to hardly fill 1 quart!. new filter again and new oil and its holding 50 psi at idel. and not draining a drop anywhere? at this point. im confussed lol.
ok compression test checks out. oil pressure is still good. going to jegs now. its running really ruff becasue of the clogged cat. ( and now glowing ) going to pick up a catless X-pipe.
still have no effin idea where it blew the oil all out of!
I thought you said there was no oil on the dipstick. How can it only fill hardly 1 qt :scratch:
