BlackVert's DIY water injection thread
BlackVert
5,589
9
98
Bethesda, MD
i plan to to screw one of these nozzles backwards into one of these bushings:
and then screw that into my intake. there is already a fairly good sized hole in the intake for the bushing. i am hoping the head of the nozzle isn't too big to fit through the hole in my intake.
for the pump, i'm going to try using a windshield washer pump at first.
i will turn it on and off by hand (at least for now) with a little switch in the cabin.
*edit* i think i should use the above hobbs switch instead *edit*
i will try attaching the pump to the nozzle with a rubber hose and a zip tie.
sounds pretty ghetto, huh?
costs so far:
Code:
$17 - universal windshield washer pump
 11 - 2 nozzles (McMaster-Carr, #s 3178K63, 3178K75)
 24 - hobbs switch (ATP turbo, #ATP-BCS-003)
  5 - 5 feet of rubber hose
  2 - switch from Radio Shack
 59 - within my budget, so far.
Yellow95 over at the Corral (Gary Gant) and I designed a DIY water injection setup years ago - if you need some tech about that, check out my web page (http://www.lasotaracing.com) and go to the tech articles - I moved the tech article over there.
The McMaster Carr nozzles work very well - I think I used a 5M for my KB when I had it. I also used a bushing, but I made it myself. Its called a 'hex nipple' and you can get it in any hardware store - get a 1/4" hex nipple, then tap the inside part for 1/8" NPT thread - the sprayer will screw right in - I ALWAYS used red Loctite so it never came apart. I also show on the website where we found one of the best areas to inject before the blower. Since then a couple of people have injected in the discharge manifold with good results. The 5M nozzle at 14# of boost dropped my ACTs from probably close to 300* to just under 200*.
Hope this helps you all out.
Don
i probably should include a solenoid ... add $13 more to the total ..
http://www.poweraire.com/products/valves/solenoidvalves/valve-mini.php
Code:
 13 - Solenoid (PowerAire #2MS10/3212DC)
 70 - within my budget, so far.
if i get to $100, then i might abort and decide it's not the savings. in that cas, i'd get the stage 2 system from snow performance and be done with it.
The nozzles got here from McMaster-Carr in 1 day :nice:
The nozzle is 1/8" NPT and it fits in the 1/4" x 1/8" bushing (in the first picture) that fits in the port on the blower, but the threads don't go all the way through, so I can't put it in backwards yet. Also, the head of the nozzle is too big to fit thru the hole, so I'll have to grind it if I want to use it in the blower. :mad:
94TURBO5 O said:
LOL I was ready to inject that blower and tap the nozzles 2 days before it came off. Do you already know where to tap the nozzles?
There is already a 1/4" NPT threaded tap on the vacuum side of the blower. I'm hoping to use that. I'm using it now for the PCV, but I can TEE that into either the tree or the emissions vacuums that are using the other 2 ports.
haulbalz said:
I WANNA KNOW HOW THIS TURNS OUT
It turns out that Eades (Chris) is selling his Snow Stage 2 kit, and the price is good enough that I have decided to take his and be done with it. And the Snow nozzles don't have the problem with the heads not fitting through the hole, so I won't need to machine the nozzle either :nice:
I still plan to complete my kit as time permits though, installing it before the throttle body for fun and to compare it to the Snow Kit. I might end up using mine for cooling (water only) under normal driving and the Snow kit (with methanol) for when it is under boost ...
My goal for my DIY injection system is to cool the intake charge under normal driving conditions (not WOT).
To that end, I want to be able to have it inject my "liquid of choice" under the following conditions:
- when the voltage from the ACT is over some value I can control with a dial (e.g. - 3.2 volts)
- when the voltage from the MAF is over some other value I can control with a dial (e.g. - 1.6 volts)
I am working on the circuit for that, and I think I am pretty close, but I am still messing around with it.
So far, here are the components in the circuit:
- 1 POTENTIOMETER for the ACT threshold dial
- 1 POTENTIOMETER for the MAF threshold dial
- 2 OP-AMPs (in a single IC) to detect when the ACT and MAF voltages reach their thresholds
- 2 NPN TRANSISTORs to AND the signals from the OP-AMPs together
- 2 RESISTORs to force the current across the TRANSISTORs to the RELAY (not thru the bases)
- 1 RELAY to provide power to the secondary circuit (with the pump)
- 1 LED to tell me when the PUMP is activated
I am currently using POTENTIOMETERs to simulate the outputs of the MAF and the ACT.
I have it turning on the LED at the right time :cheers:, but I have no confidence in it yet.
I'll post a schematic later when I can ...
Here's the schematic:
The 2 POTs are how you adjust the trigger voltages for the ACT and MAF
So far, I have burned up one op-amp and a potentiometer on my breadboard ... :nice:
