I have just switched out my brake lines to stainless and installed a set of original front discs and an original proportion valve over the old drum stuff.
I'm having a hard time bleeding the rear drums. I have a vacuum gage that I'm using to bleed the brakes. The fronts tested fine, but the rear drums have no fluid after applying the vacuum gage to both sides. I do notice a hissing sound coming from the proportion valve(?) when under 15-20 inches of vacuum. Is this thing holding up my bleeding efforts? The factory manual doesn't mention anything special besides setting the caliper pistons to their proper position.
