blinkers wtf
  • Thread starter Thread starter 873Stang
  • Start date Start date Sep 15, 2007
873Stang
221
riverside
Sep 15, 2007
  • Sep 15, 2007
so my blinkers work when they want to!!!!! what the hell man???? what culd it be thank you guys!!!!!!
BigHairyMonkey
411
Houston (Bellaire) TX
Sep 15, 2007
  • Sep 15, 2007
check the grounds. check the bulbs. check the harness to and from the bulbs for cracks/splices/etc
bloopbloob
578
Alberta
Sep 15, 2007
  • Sep 15, 2007
is it just turn signals or hazards or both? they have seperate flashers. u might want to try swapping the two to determine if its the flasher or something in your wiring. cheap to replace also, like $10 or less
cjones
1,561
Avondale, AZ
Sep 16, 2007
  • Sep 16, 2007
if the hazards work and the turn signals don't. try moving the turn signal arm(on switch) a bit more up or down and see it that causes them to work, if so, the contants in the switch may be bad.
are you on the brakes when they don't work??
corvetteguy
71
  • Sep 16, 2007
Why not just
replace the blinker. A cheap fix.
You do know where it is located on
the fox?
408gt91
114
N.H.
Sep 16, 2007
  • Sep 16, 2007
try this when you start your car and they dont work.when you turn the key forward and it starts you let go of the ignition and it kicks back a little.sometimes it doesnt so while its running,with out turning off the ignition turn it towards you backwards to get rid of the slack.they get worn.mine did that and blinkers worked off an on.my friend owns a garage and told me about this.
C
Another lighting issue
  • ChrisCruz1972
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
Electrical Foxbody Dash & Hazard lights not working
  • sjmcr
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 27, 2025
Mindseye007
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
