Block heater plug, where?
  • Thread starter Thread starter HighMileage
  • Start date Start date Aug 7, 2004
H
HighMileage
37
  • Aug 7, 2004
Is there even a block heater plug on the 5.0 block?
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Aug 8, 2004
  • Aug 8, 2004
I'm sure it was an option in Canada -- but not a standard thing. And I'm not sure how the heater would work -- whether it would be a replacement dipstick or an actual heating element in the pan.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,114
224
Massachusetts
Aug 8, 2004
  • Aug 8, 2004
My Mustang has the optional Block Heater. It's a Massachusetts car.
Plug is located int he LX grill off to the side. No real special holster or anything, it's just hanging out there.
The wire runs down the passenger side fender and under the passenger header
One of the freeze plugs in the block is removed and swapped with the block heater plug. It's just a thicker freeze plug with the attachment to plug the wire for the heater in. WHen you plug it in, it gets pretty warm and does a good job of keeping the coolant warm at night.
I've used my block heater quite a few times this past winter when we had 2 weeks straight of dipping down near -20 at night and highs of 3-5 degrees.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Aug 8, 2004
  • Aug 8, 2004
So the factory block heater heats coolant instead of oil? I thought they all did oil. Learned something new. Interesting...
H
HighMileage
37
  • Aug 8, 2004
Under the passenger header ... Great and Thanks!
Now, to take a look and see if I could put one in myself.
If it's buried, it may be tougher than any spark plug.
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
L
Engine New guy heater hose question. 85 gt 4bbl.
  • linemech31
  • Jan 17, 2026
Fox 5.0 Mustang Tech Jan 20, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
