Blow By.... Questions
  • Thread starter Thread starter Hickfied
  • Start date Start date Dec 24, 2005
Hickfied
413
Morganton, NC
Dec 24, 2005
  • Dec 24, 2005
long post, sorry, but I really need help
To start off, I have roughly 164K miles on a completly stock engine in my 89 GT. The last four months when it is cold and the RPM's go over 4000, I get smoke out the exaust, and when going up hills or putting a load on the engine, there is a rattle.
I have let it set for the last two months, only letting it warm up twice a week. Well now it wont idle and just studers, untill it dies, and there are droplets of oil comming out of the exaust tips on the drivers side (No H pipe, just a pipe on each side connecting the header to the muffler) So I pulled my plugs, and they are covered in oil. If I hold the RPM's at 1000 or higher, it will run, but still has blows blue smoke over 4000 RPM.
Would massive amounts of oil be causing it to studer? I was wondering if I could hone the cylinders, and put in new rings, if it would last 1000 miles or less... untill I have the money next year to do a real rebuild?
joel5.0
429
Puerto Rico
Dec 24, 2005
  • Dec 24, 2005
Yes...massive amounts of oil will cause the plugs not to fire and the studder.
Looks like you've reached a decision point of either doing a band-aid repair while funds become available for a real rebuild, BTDT and it's not worth it. The heads (oil seals, valve guides, etc) are also a factor. If engine blowby (check condition of throttle body openings for oil) is not obviously bad, a heads resto would provide you the time for the funding efforts.
You could also have something as simple as a bad PCV valve and mesh screen that need replacement, BTSTDT also. Again, while you get the resources for a rebuild . LUK
Black1987Stang
1,422
Jersey Shore
Dec 24, 2005
  • Dec 24, 2005
I think its something that went bad as in not the motor going...unless u were having motor problems before u parked it for the long time.
Are ALL the plugs wet?
I would look for maybe a misifring problem first....although i doubt there still would be oil in the cylinders....but could also be something with the pcv, etc.
bill302
2,131
alabama,gadsden
Dec 24, 2005
  • Dec 24, 2005
run a compression test and post results.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
