you cant hear bad rings. and bad rings would cause constant smoke from the tailpipes all the time. smoke only when your floor is a good sign of worn valve guides and/or bad valve seals.
have you noticed a performance decrease?? how many miles on the motor??
what color is the smoke like roland said?
blue smoke is oil... usually either rings or guides or seals.
white smoke is water/coolant... bad head gaskets or intake leaks etc
black smoke is fuel... indicates an extreme rich condition
if it runs good and just puffs a little smoke under hard acceleration thats not too bad.if you want to rebuild i'd looking into doing it yourself. if all you want to do is a basic re-reing.
mine used to puff smoke at high RPM/ under a hard shift at WOT on my old 145k stock engine. it was just bad seals
i'd do a basic tune-up
plugs ( can read old ones and get more info on what the engine is doing)
wires
cap/rotor
o2s
oil change
flush radiator
i'd find the CEL issue before anything, the ECU throws the CEL. the computer doesnt know anything about if the engine is burning oil or water etc. basically all it does is take coolant, air temp readings, monitor exhaust gases via o2s and determine how much fuel to give the engine. when a CEL comes on its usually showing a bad or misadjusted sensor, can also have a code for rich or lean conditions
