Watch it. Paul Wall is an Eades imitator. Eades is the original - and he will slaughter you.yobi1kanobi said:the heads will be cleaned up as ports are concerned just smooth out the edges and the valve job being seperate just 3 angle job u know what that is?.. eades50 if you dont have any good input or anything good to say stay the f@#k out of my post..
30's for n/a should be fine....And as I said you should be fine with the 42's on with forced induction with the in tank pump and t-rex, especially if you get a meth inj kit.yobi1kanobi said:Alright i see what you mean maybe a set of 55# sounds better for the blown application....note taken. But what about my 30# for the N/A setup..as far as the heads are concerned. the car was sitting for a year without starting it up so i want the machine shop to check spring. vavle seat, and clean all the carbon deposits..
eades5.0 said:I thought u were doing it?
let me know when it is all here, ill come help you get it together. by the way, i talked to walt over at pro motion today and ended up buying a tko500 and a kustom clutch from him after a while on the phone.yobi1kanobi said:i need the machine work and notching so the assembly is like 450 buck why not have someone that does this all day do it for you. Know what I mean. Plus he is building the short block i am putting the rest together.
Green 94 5.0 said:let me know when it is all here, ill come help you get it together. by the way, i talked to walt over at pro motion today and ended up buying a tko500 and a kustom clutch from him after a while on the phone.
he sure can make a sale cant he...
