BlownStangGT's pass time...
  • Thread starter Thread starter BlownStangGT
  • Start date Start date Sep 10, 2009
BlownStangGT
REPEAT
3,860
Lancaster, PA
Sep 10, 2009
  • Sep 10, 2009
Fig. we could play a little pass time with some fake money haha As of right now, I am headed down to the track on Wed. for the cars first time EVER gracing the drag strip. Def. not my first time, but first time with this puppy. Car will be on 17" Et streets and full weight. Havnt weighed the car yet, but I guess 3500+??? Suspension def. not set up for the track, set up for corner carving haha, but should at least hook. So....lets begin Pass Time....put your bets in now! If you need any questions awnsered, post them up
LaserSVT
3,548
233
Sep 10, 2009
  • Sep 10, 2009
12.42@112mph
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Sep 10, 2009
  • Sep 10, 2009
17.4 @ 92mph
j/k.....12.73 @ 107 mph
since your a noob at the track with this car im shooting high...good luck man!
sneaky98gt
2,387
144
114
NC State University
Sep 10, 2009
  • Sep 10, 2009
Is what's in your sig what the car has? If so, imma say 12.22@115.
-Will
BlownStangGT
REPEAT
3,860
Lancaster, PA
Sep 11, 2009
  • Sep 11, 2009
-Will
Here is what is done that would matter:
Rear
Eaton Posi
31spline moser axles
3:73 gears
Transmission
Tremec 3650
Pro 5.0 shifter
Mcleod Clutch
Steeda Adjustable Clutch Cable, Double Hook Quadrant and Firewall Adjuster
Cooling
2003 Cobra Radiator
Engine
Vortech V2 SQ Supercharger
3.1" Vortech Pulley
AFM Powerpipe
42lb Injectors
Pro-M 3" Pro Tube MAF
2003 Cobra fuel tank and pump
Bullitt Intake Kit
Denso Iridium Spark Plugs
Accufab Throttle Body
Tread Stone Front Mount Intercooler Kit
Suspension
Kenny Brown Sub Frame Connectors
Maximum Motorsports 4-Point K-Member Brace
Maximum Motorsports Panhard Bar with Aluminum Rod
Maximum Motorsports Heavy Duty Adjustable Rear Lower Control Arms
Steeda Heavy Duty Adjustable Upper Control Arms
MM Rear Adjustable Sway Bar
Eibach Sportline Springs
Bilstein HD front struts
Bilstein HD rear shocks
Maximum Motorsports Caster/Camber Plates
Maximum Motorsports Urethane Pinion Snubber
Front spring isolators
Rear spring isolators
Solid Steering Shaft
Maximum Motorsports Aluminum Rack Bushings, center drilled
Front Swaybar bushings
Front Swaybar end link bushing kit
Front control arm bushings, urethane
Exhaust
Bassani Stainless Steel X Pipe with high flow cats
Mac 3inch dumps
stangGT97
1,299
Boston area, MA
Sep 11, 2009
  • Sep 11, 2009
No idea, but I <3 your car
J
jomull55
202
lucas, OH
Sep 11, 2009
  • Sep 11, 2009
12.32 @ 119
BlownStangGT
REPEAT
3,860
Lancaster, PA
Sep 19, 2009
  • Sep 19, 2009
Well the car did not blow up.....becuase I didnt make it to the track. They were calling for rain and I decided to call it off and find another day to go. So hopefully within the next couple of weeks we will find a better day.....thats all good with me...cooler weather is great
GDawg
1,469
Nevada
Sep 19, 2009
  • Sep 19, 2009
What's your elevation? I'm guessing if you've never raced it before, you won't know how to hook up real well. So I'm saying mid 13s.
I have Eagle F1 GS-D3 tires that are great for the curves but still can't handle my torque. I have horrible 60' times (2.8). But then again, I have a manual. I spin through first and second and don't hook till third gear.
BlownStangGT
REPEAT
3,860
Lancaster, PA
Sep 19, 2009
#10
  • Sep 19, 2009
  • #10
Track elevation is 320'. Track is known to be pretty quick track, its where I have ran all my other cars at.
Yeah, this will be the first time in this car down the track, but have been down the track plentry of other times, just not in this car. So luaanching will be interesting the first pass
Car will also be running MT Et Streets 26x11.5x17 at 15psi to start.
BlownStangGT
REPEAT
3,860
Lancaster, PA
Sep 27, 2009
#11
  • Sep 27, 2009
  • #11
Well hopefully I will be getting to the track on wed. Weather looks good so far. 59* as a high....should be a nice cool night at the track!
Niterydr85
174
Pasadena, Maryland
Oct 2, 2009
#12
  • Oct 2, 2009
  • #12
So did you make it to the track?
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Oct 2, 2009
#13
  • Oct 2, 2009
  • #13
et streets are pretty much slicks, they are NOT a radial, but a bias tire, start at 11lbs cold, after you burn out it will be at 15psi or more, i started at 15 and spun bad, went to about 20 when hot, start with 11 cold and go from there...........
BlownStangGT
REPEAT
3,860
Lancaster, PA
Oct 2, 2009
#14
  • Oct 2, 2009
  • #14
Once agian I did not make it! They were calling for scattered rain, but it ended up going ok out, but I got stuck at work. Next wed. I work....so it looks like wed. Oct 14th haha........I swear this car DOES NOT want to go to the track haha....it keeps RESISTING!
Yeah, I will try the pressre lower! Thanks for the suggestion!
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
D
94 GT cold start takes a long time cranking. Help!
  • DeanS
  • Aug 6, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2024
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
