Blue Smoke
  • Thread starter Thread starter RoadKill96
  • Start date Start date Jan 30, 2009
RoadKill96
39
Victorville CA
Jan 30, 2009
  • Jan 30, 2009
Hello Fellow Stangnet member's i need some help. Everytime i Start my car Blue smoke comes from the Left tail pipe yes i have two of them just one of them smokes im not sure if its rings or valves ive put my code reader on no codes and nothing. The car has alot of miles on it other than that i dont know hopefully Jrichker can help on this one.
Thanks Pete
pony502
23
Liverpool N.Y.
Jan 30, 2009
  • Jan 30, 2009
Deffinately time to refresh that engine either your rings are worn or your valve guides are bad. Probably lost some compression on that side of the engine as well. You could do a compression check to find out how much if you wanted. should be between 150-165 psi.
88mouse
630
Mooresville nc
Jan 30, 2009
  • Jan 30, 2009
How many miles on the motor? Ford does not use a very good valve stem seal from the factory. I would check the compression, if the compression checks out good. I would try a set of valve stem seals.
Bullitt347
I have been doing it wrong this whole time
4,061
3,133
204
Middle of Maine
Jan 30, 2009
  • Jan 30, 2009
If it smokes on start up only, then valve stem seals and maybe valve guides. If it smokes on hard acceleration then its the piston rings. If it smokes on deceleration only, it could be a blown intake gasket (under intake ) or a pcv sucking oil from a valve cover with no baffle. If it smokes all of the time, then a rebuild is in order.
RoadKill96
39
Victorville CA
Jan 31, 2009
  • Jan 31, 2009
It only smoke's when i first start it up thats it. But i have over 200K on the motor Yea i think its time to REBUILD. Hey Jrichker wanna help????
Maryland Stang
1,656
30
39
Greenville, NC
Jan 31, 2009
  • Jan 31, 2009
Valve seals, no doubt.
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
